Giriş
These steps will help you fix your lint trap on a Kenmore 67123 dryer. If your lint trap won’t close all the way this guide will show you how to fix that problem. This guide will help you step by step on how to remove the lint trap and see inside. This will help to see why the lint trap won’t close all the way. This is an important guide because your dryer could start on fire if the lint trap isn’t closing all the way. I hope this guide will help someone that has the same problem I did.
Aletler
Parçalar
Using your Phillips #0 remove two 12.7 mm screws on each side of the door.
Remove the door.
To put everything back start with the door, then putting the lint trap back on and then you are done. This guide is very simple. When you finish you should not have any screws left.
