Giriş
This guide will teach you how to remove the casing, remove the pin of the pedal and replace the spring for the pedal. You will need a medium sized Phillips screwdriver and an all-purpose wrench (although any small flat wrench will work).
Neye ihtiyacın var
Close the casing again and fasten the casing with the screws. You have now successfully replaced the spring!
2 farklı kişi bu kılavuzu tamamladı.
