Ana içeriğe geç
How to Replace a Nequare Cordless Vacuum S182 Filter
  1. How to Replace a Nequare Cordless Vacuum S182 Filter, Filter: adım 1, 2 resimden 1. How to Replace a Nequare Cordless Vacuum S182 Filter, Filter: adım 1, 2 resimden 2.
    • Locate the black button to release the white motor unit from the rest of the vacuum cleaner.
  2. How to Replace a Nequare Cordless Vacuum S182 Filter: adım 2, 2 resimden 1. How to Replace a Nequare Cordless Vacuum S182 Filter: adım 2, 2 resimden 2.
    • Hold down the black button to remove the white motor unit above and gently pull the motor unit upwards.
  3. How to Replace a Nequare Cordless Vacuum S182 Filter: adım 3, 2 resimden 1. How to Replace a Nequare Cordless Vacuum S182 Filter: adım 3, 2 resimden 2.
    • Press the release button at the side of the dust canister to dispose of the debris.
    • Be sure to hold the the canister over a garbage can to avoid a spill.
  4. How to Replace a Nequare Cordless Vacuum S182 Filter: adım 4, 3 resimden 1. How to Replace a Nequare Cordless Vacuum S182 Filter: adım 4, 3 resimden 2. How to Replace a Nequare Cordless Vacuum S182 Filter: adım 4, 3 resimden 3.
    • After emptying the debris, hold down the black button, then twist and pull the canister out.
  5. How to Replace a Nequare Cordless Vacuum S182 Filter: adım 5, 2 resimden 1. How to Replace a Nequare Cordless Vacuum S182 Filter: adım 5, 2 resimden 2.
    • Take the filter out and dispose of it.
  6. How to Replace a Nequare Cordless Vacuum S182 Filter: adım 6, 2 resimden 1. How to Replace a Nequare Cordless Vacuum S182 Filter: adım 6, 2 resimden 2.
    • Remove the black part by gently pushing from inside of the canister.
  7. How to Replace a Nequare Cordless Vacuum S182 Filter: adım 7, 2 resimden 1. How to Replace a Nequare Cordless Vacuum S182 Filter: adım 7, 2 resimden 2.
    • Clean both the canister and the black part either by rinsing it out or using a wash cloth.
  8. How to Replace a Nequare Cordless Vacuum S182 Filter: adım 8, 3 resimden 1. How to Replace a Nequare Cordless Vacuum S182 Filter: adım 8, 3 resimden 2. How to Replace a Nequare Cordless Vacuum S182 Filter: adım 8, 3 resimden 3.
    • Put the black part back into the canister and put in the new filter.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Oghenefejiro Egede
181 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 46
Her zaman: 1,262
