Ana içeriğe geç
How to replace a bikini buckle
Neye ihtiyacın var
  1. How to replace a bikini buckle, Locate the defect: adım 1, 3 resimden 1. How to replace a bikini buckle, Locate the defect: adım 1, 3 resimden 2. How to replace a bikini buckle, Locate the defect: adım 1, 3 resimden 3.
    • In most cases, the buckle will not have broken, but just the stitching keeping the seam together
    • We will re-use the buckle
  2. How to replace a bikini buckle, Tidy the broken seam: adım 2, 3 resimden 1. How to replace a bikini buckle, Tidy the broken seam: adım 2, 3 resimden 2. How to replace a bikini buckle, Tidy the broken seam: adım 2, 3 resimden 3.
    • Carefully remove the old broken threads from the defective seam, to obtain a clean area again.
  3. How to replace a bikini buckle, Position the buckle and pin it: adım 3, 3 resimden 1. How to replace a bikini buckle, Position the buckle and pin it: adım 3, 3 resimden 2. How to replace a bikini buckle, Position the buckle and pin it: adım 3, 3 resimden 3.
    • Thread the strap back through the buckle and hold in place with your hand.
    • Check that the alignment is correct buy clipping it onto the other buckle
    • Note: this buckle is a sliding design which will only work on one alignment. Other buckles work in different ways, so be sure to check before sewing.
    • Pin the strap in place around the buckle, to secure it before sewing
  4. How to replace a bikini buckle, Sew the broken seam: adım 4, 3 resimden 1. How to replace a bikini buckle, Sew the broken seam: adım 4, 3 resimden 2. How to replace a bikini buckle, Sew the broken seam: adım 4, 3 resimden 3.
    • Use a sewing machine to re-sew the broken seam
    • Offer-up the seam to the sewing machine, depress the foot, and remove any pins which are in the way of the needle
    • Make a locking stitch, followed by a straight stitch. Repeat the straights stitch 1-2 times and finish with another locking stitch.
  5. How to replace a bikini buckle, Reinforce the seam if needed: adım 5, 3 resimden 1. How to replace a bikini buckle, Reinforce the seam if needed: adım 5, 3 resimden 2. How to replace a bikini buckle, Reinforce the seam if needed: adım 5, 3 resimden 3.
    • Add a second row of stitching to reinforce the fixation, if needed
  6. How to replace a bikini buckle, Finished and ready!: adım 6, 3 resimden 1. How to replace a bikini buckle, Finished and ready!: adım 6, 3 resimden 2. How to replace a bikini buckle, Finished and ready!: adım 6, 3 resimden 3.
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
    • You can fasten the buckle and stretch the straps to check if the repair is secure
Sonuç
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
9.298 İtibar
64 adet Kılavuz yazıldı
Ekip
INTERSPORT INTERSPORT üyesi
Community
23 Üyeler
161 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 173
