Giriş
Lost a stud on your Icebug shoes/boots?
No problems! Icebug's BUGrip technology is designed so that you will have a good grip even if you drop one or even a pair of studs per shoe. If, on the other hand, you lose more, you should add new ones - and you can easily do it yourself.
You can order the studs free of charge from Icebug's customer services. Email Icebug at info@icebug.se stating which shoe model you have. Send along photos showing the shoes in full and a clear image of the outsoles. Tell us how many studs you are missing, and to which address you want them sent.
With the help of the photos, we decide if it is worth sending out replacement studs. If too many are missing, or the shoes are too old or worn, it is not certain that the grip can be restored.
We will send your new studs shortly and you will then easily mount them there with elastic glue (for example RubberFix or Shoe Goo) and pliers.
See how it's done in the video here:
Videoya Genel Bakış
New BUGrip studs
Elastic Glue (For example RubberFix or Shoe Goo)
Pliers
1. Clean the holes where you have lost studs
2. Fill the holes with glue
3. Apply the studs - tilt, push and twist
🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Enjoy the outdoors!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
- Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
- Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
- Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
