Ana içeriğe geç
How to replace the door knob
Neye ihtiyacın var
  1. How to replace the door knob, Remove the screw holding the handle: adım 1, 1 resimden 1.
    • It is advisable to work with two people, one holding the outer handle on the outside and the other unloading the screw on the other side.
    • Remove the two screws.
  2. How to replace the door knob, Remove the handle: adım 2, 1 resimden 1.
    • Use pry bar carefully pry around, you can remove both sides of the door handle.
    • There is usually a plastic washer between the handle and the door, taking care not to damage it.
    • There will be a metal square shaft connected between the handle. Be careful not to lose it when removing the inside handle because the shaft is inside and outside.
  3. How to replace the door knob, Pay attention to the square shaft: adım 3, 1 resimden 1.
    • Pay attention to the installation direction of this square shaft. Do not knock it off when removing the handle.
Sonuç
Reversing the steps to know hot to install the know. It's easier than your thought , isn't it?
5 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
zh en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Z.Heng
3.610 İtibar
3 adet Kılavuz yazıldı
Bir Yorum
图文并茂,生动形象,谢谢你的分享!
Conti - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 1,270
