Ana içeriğe geç
How to restore UV Damaged Headlights
Neye ihtiyacın var
  1. How to restore UV Damaged Headlights, How to restore UV Damaged Headlights: adım 1, 3 resimden 1. How to restore UV Damaged Headlights, How to restore UV Damaged Headlights: adım 1, 3 resimden 2. How to restore UV Damaged Headlights, How to restore UV Damaged Headlights: adım 1, 3 resimden 3.
    • In a shaded area, apply masking tape on the outer edges of the headlight assembly.
  2. How to restore UV Damaged Headlights: adım 2, 3 resimden 1. How to restore UV Damaged Headlights: adım 2, 3 resimden 2. How to restore UV Damaged Headlights: adım 2, 3 resimden 3.
    • Use the spray bottle of soapy water to wet the 800-grit sandpaper.
    • Spray the sandpaper liberally and make sure it is completely wet.
  3. How to restore UV Damaged Headlights: adım 3, 3 resimden 1. How to restore UV Damaged Headlights: adım 3, 3 resimden 2. How to restore UV Damaged Headlights: adım 3, 3 resimden 3.
    • Spray the headlight with soapy water and sand the headlight's surface.
    • Continuously spray the headlight and the sandpaper with water. The surface must stay wet during sanding.
    • Sand the headlight in a circular motion throughout this step.
    • Stop sanding when the entire headlight appears foggy.
  4. How to restore UV Damaged Headlights: adım 4, 3 resimden 1. How to restore UV Damaged Headlights: adım 4, 3 resimden 2. How to restore UV Damaged Headlights: adım 4, 3 resimden 3.
    • Spray the 2000-grit sandpaper with soapy water and ensure it is completely wet.
    • Sand the headlight in a circular motion while maintaining the surface wet with soapy water.
    • Stop sanding when the headlight appears slightly less cloudy (than in the previous step).
  5. How to restore UV Damaged Headlights: adım 5, 3 resimden 1. How to restore UV Damaged Headlights: adım 5, 3 resimden 2. How to restore UV Damaged Headlights: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Microfiber Cleaning Cloths
    $3.99
    • Lightly wet a small section of a clean microfiber cloth with 70% isopropyl alcohol.
    • Rub down the entire headlight surface with the microfiber cloth.
  6. How to restore UV Damaged Headlights: adım 6, 2 resimden 1. How to restore UV Damaged Headlights: adım 6, 2 resimden 2.
    • Carefully peel off the old masking tape.
    • Use newspaper to cover the car's body using masking tape to hold it down.
    • Shield any gaps and use newspapers at least a foot long.
    • The newspaper will protect the car from overspray in the next step.
  7. How to restore UV Damaged Headlights: adım 7, 3 resimden 1. How to restore UV Damaged Headlights: adım 7, 3 resimden 2. How to restore UV Damaged Headlights: adım 7, 3 resimden 3.
    • Use a clear coat to spray the headlight.
    • Follow the clear coat manufacturer's instructions for spraying distance, number of coats, and drying time.
    • Apply the clear coat in well-ventilated conditions.
  8. How to restore UV Damaged Headlights: adım 8, 3 resimden 1. How to restore UV Damaged Headlights: adım 8, 3 resimden 2. How to restore UV Damaged Headlights: adım 8, 3 resimden 3.
    • Apply a small amount of compound to a clean microfiber applicator pad.
    • Dap the headlight's surface with the compound.
    • Work the compound into the headlight.
    • Use heavy pressure and rub in a circular motion when working the compound into the headlight.
  9. How to restore UV Damaged Headlights: adım 9, 3 resimden 1. How to restore UV Damaged Headlights: adım 9, 3 resimden 2. How to restore UV Damaged Headlights: adım 9, 3 resimden 3.
    • Wipe the headlight with a clean microfiber cloth.
    • Apply a small amount of polish onto a new, clean microfiber applicator pad.
    • Dap the polish onto the headlight, then work the polish onto the headlight.
  10. How to restore UV Damaged Headlights: adım 10, 3 resimden 1. How to restore UV Damaged Headlights: adım 10, 3 resimden 2. How to restore UV Damaged Headlights: adım 10, 3 resimden 3.
    • Wipe the headlight with the clean side of a microfiber cloth.
    • Use a microfiber cloth to scoop about a quarter-sized amount of wax.
    • Rub the wax into the headlight with medium pressure and in a circular motion.
    • Continue rubbing until there is no more visible wax.
  11. How to restore UV Damaged Headlights: adım 11, 3 resimden 1. How to restore UV Damaged Headlights: adım 11, 3 resimden 2. How to restore UV Damaged Headlights: adım 11, 3 resimden 3.
    • Wipe the headlight with a clean side of microfiber cloth.
    • Carefully remove the newspaper and masking tape.
    • Enjoy the clear road with your newly restored headlights!
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Patrick Abelgas
235 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 29
Son 30 gün: 60
Her zaman: 867
