Ana içeriğe geç
How to rewire a Nostalgia Electrics PCM805
Neye ihtiyacın var
  1. How to rewire a Nostalgia Electrics PCM805, Nostalgia Electrics PCM805 Wiring Teardown: adım 1, 2 resimden 1. How to rewire a Nostalgia Electrics PCM805, Nostalgia Electrics PCM805 Wiring Teardown: adım 1, 2 resimden 2.
    • Locate the tie strap holding the wires and cut with a pair of scissors.
    • Use care not to snip the wires.
  2. How to rewire a Nostalgia Electrics PCM805: adım 2, 3 resimden 1. How to rewire a Nostalgia Electrics PCM805: adım 2, 3 resimden 2. How to rewire a Nostalgia Electrics PCM805: adım 2, 3 resimden 3.
    • Make note of the wiring arrangement of each bundle before this step.
    • Using wire cutters, cut each wire as close to the wire connector as possible.
    • Cut the wires in both bundles.
    • To reassemble the cotton candy maker after cutting the wires, follow our rewiring guide.
  3. How to rewire a Nostalgia Electrics PCM805, How to rewire a Nostalgia Electrics PCM805: adım 3, 2 resimden 1. How to rewire a Nostalgia Electrics PCM805, How to rewire a Nostalgia Electrics PCM805: adım 3, 2 resimden 2.
    • Using the wire stripper, remove 1/2 inch of the wire insulation at the end of each wire to expose the bare wire for re-connection.
  4. How to rewire a Nostalgia Electrics PCM805: adım 4, 3 resimden 1. How to rewire a Nostalgia Electrics PCM805: adım 4, 3 resimden 2. How to rewire a Nostalgia Electrics PCM805: adım 4, 3 resimden 3.
    • Twist the exposed ends of the wires so that they stay together.
    • Push the wire cap onto the exposed ends while holding the wires and twist in a clock-wise direction until it is tight.
    • Repeat this process for both bundles of wires.
    • Do not attempt to power on the device without the wire caps on or mix wires between the bundles.
Bitiş Çizgisi
Carlton
672 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-5, Hickman Winter 2015 USF Tampa, Team 3-5, Hickman Winter 2015 üyesi
USFT-HICKMAN-W15S3G5
5 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
DO NOT TRY THIS..it broke my machine TO NOT TRY THIS
Izzy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 19
Her zaman: 655
