Ana içeriğe geç
How to unpair a Mitsubishi MMCS NR-242 Map SD Card
Neye ihtiyacın var
  1. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Identify your Revision: adım 1, 1 resimden 1.
    • You can find the Version Number of your MMCS printed on the top right corner of the unit.
    • You need either a Version W-11 or W-12. In this case the Version Number is W-12, so we can proceed.
  2. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Download the Unlock Binary: adım 2, 1 resimden 1.
    • You can download the Binary at this site.
    • Download the Binary.
    • Extract the NK.BIN file from the W12_MAP_UNLOCKER.rar archive using 7-Zip.
  3. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Move the File: adım 3, 1 resimden 1.
    • The SD card needs to be formatted to FAT32. If it’s not already formatted to FAT32 and you don’t know how to do it, you can take a look at this guide.
    • Copy the NK.BIN file to the root directory of the SD Card.
  4. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Flip up the Display: adım 4, 2 resimden 1. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Flip up the Display: adım 4, 2 resimden 2.
    • Press the OPEN-Button.
    • Press the Monitor OPEN-Button on the screen.
  5. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Swap the SD Cards: adım 5, 2 resimden 1. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Swap the SD Cards: adım 5, 2 resimden 2.
    • Remove the SD Cards from both the MAP and USER-Slots.
    • Insert the new SD Card into the USER-Slot.
    • Close the display by pressing the Open-Button again.
  6. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Reboot the Unit: adım 6, 1 resimden 1.
    • Long press both the NAVI MENU and AUDIO-Buttons to reboot into unlocker mode.
  7. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Insert the paired SD Card: adım 7, 1 resimden 1.
    • Open the display again by following the instructions in Step 4
    • Insert the paired SD Card into the MAP-Slot.
    • Wait 5-10 Seconds for the unpairing process to be completed before removing it again.
  8. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Return the SD Cards: adım 8, 1 resimden 1.
    • Return the SD Cards you removed in Step 5 back to their respective Slots.
  9. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Exit the Unlocking Mode: adım 9, 1 resimden 1.
    • Long press both the NAVI MENU and AUDIO-Buttons again to reboot back into standard mode.
Sonuç
Drive safe!
Sebastian
21.643 İtibar
60 adet Kılavuz yazıldı
Ekip
German Translators German Translators üyesi
Community
29 Üyeler
768 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 12
Son 30 gün: 87
Her zaman: 927
