Ana içeriğe geç
Hp 15-f305dx Keyboard Replacement
Neye ihtiyacın var
  1. Hp 15-f305dx Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
  2. Hp 15-f305dx Keyboard Replacement: adım 2, 1 resimden 1.
    • Turn the computer upside down on a flat surface.
  3. Hp 15-f305dx Keyboard Replacement: adım 3, 3 resimden 1. Hp 15-f305dx Keyboard Replacement: adım 3, 3 resimden 2. Hp 15-f305dx Keyboard Replacement: adım 3, 3 resimden 3.
    • Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery.
  4. Hp 15-f305dx Keyboard Replacement: adım 4, 2 resimden 1. Hp 15-f305dx Keyboard Replacement: adım 4, 2 resimden 2.
    • Lift the battery from the middle and then pivot it outward to remove it from the computer.
  5. Hp 15-f305dx Keyboard Replacement, Keyboard: adım 5, 1 resimden 1.
    • Flip the laptop around.
  6. Hp 15-f305dx Keyboard Replacement: adım 6, 2 resimden 1. Hp 15-f305dx Keyboard Replacement: adım 6, 2 resimden 2.
    • Remove the single 7 mm screw from the top middle of the laptop using a Phillips #0 screwdriver.
  7. Hp 15-f305dx Keyboard Replacement: adım 7, 2 resimden 1. Hp 15-f305dx Keyboard Replacement: adım 7, 2 resimden 2.
    • Pry the keyboard out of the laptop gently and flip the keyboard around.
  8. Hp 15-f305dx Keyboard Replacement: adım 8, 1 resimden 1.
    • Disconnect the connected cable from the mainboard.
Sonuç
Brandon
681 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G3, Bernier Spring 2018 UMass Dartmouth, Team S2-G3, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S2G3
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 634
