Ana içeriğe geç
Hp Pavilion dv6-2155dx Optical Drive Replacement
Neye ihtiyacın var
  1. Hp Pavilion dv6-2155dx Optical  Drive Replacement, Optical Drive: adım 1, 2 resimden 1. Hp Pavilion dv6-2155dx Optical  Drive Replacement, Optical Drive: adım 1, 2 resimden 2.
    • Flip the computer around to the back side.
    • Remove the three screws from the memory module cover.
    • Screws will not come out all the way.
    • All screws to loosen/removed in this guide will require a Phillips #01 screwdriver.
  2. Hp Pavilion dv6-2155dx Optical  Drive Replacement: adım 2, 1 resimden 1.
    • Remove the screw completely from the memory module panel to help release the Optical drive from the body of the computer.
    • The screw is 7mm long and head is 4mm wide.
  3. Hp Pavilion dv6-2155dx Optical  Drive Replacement: adım 3, 2 resimden 1. Hp Pavilion dv6-2155dx Optical  Drive Replacement: adım 3, 2 resimden 2.
    • Locate the small hole next to the eject button.
    • Get a paper clip and insert in to the small hole until you hear a clicking sound and seeing the tray pop out.
    • Before removing the optical drive, be sure that there is nothing in the drive. Optical drives are fragile so handle with care.
  4. Hp Pavilion dv6-2155dx Optical  Drive Replacement: adım 4, 2 resimden 1. Hp Pavilion dv6-2155dx Optical  Drive Replacement: adım 4, 2 resimden 2.
    • Gently pull the Optical drive out of the slot until the whole thing comes out.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Joseph Sanda
522 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-2, Isaacson Fall 2016 UMass Dartmouth, Team 2-2, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S2G2
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 760
