1. My friend gave me it for 5€ (broken lcd and touch) so i took it apart
    • My friend gave me it for 5€ (broken lcd and touch) so i took it apart
    • Yours may look different but tutorial like this should help you anyway :)
  2. That's back of Huawei ascend g510
    • That's back of Huawei ascend g510
    • It's Inexpensive android phone
    • To open pry left down corner
    • You don't need any tools for this... You can pry any corner to pop the back open
  3. First remove battery
    • First remove battery
  4. It's HB4W1H 3.7v 1750mAh (6.5Wh) Li-ion battery Don't mess with Lithium ion batteries... (And don't take apart)
    • It's HB4W1H 3.7v 1750mAh (6.5Wh) Li-ion battery
    • Don't mess with Lithium ion batteries... (And don't take apart)
    • MADE IN CHINA... As everything
  5. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  6. There are
    • There are
    • 7 black T5 screws
    • 1 white T5 screw
    • 1 black Philipps #0 screw
    • Just remove all and sort them so you don't mix them
  7. There are many clips along the sides
    • There are many clips along the sides
    • Don't pry to hard or you'll break some plastic
    • These clips really suck
  8. First undo all connectors (lcd, touch, camera, sim/sd slot)
    • First undo all connectors (lcd, touch, camera, sim/sd slot)
    • Main PCB is hold with clips and glue
    • Really frustrating to remove it... Glue or clips are everywhere
  9. That's the camera
    • That's the camera
  10. Let's take look at pcb. Unmodular and crusty... I don't like it at all
    • Let's take look at pcb.
    • Unmodular and crusty... I don't like it at all
  11. As bad as front As bad as front
    • As bad as front
  12. To separate glass (with touch)  just heat it up to loosen adhesive To separate glass (with touch)  just heat it up to loosen adhesive
    • To separate glass (with touch) just heat it up to loosen adhesive
Sonuç
16 başka kişi bu kılavuzu tamamladı.
Mateusz Bonkowski
1.252 İtibar
2 adet Kılavuz yazıldı
3 Yorum
It just won't read my sim card,i was wondering if there is a setting that has been changed?
Michael Cummins - Yanıt
I have a good idea of what you are doing and how much you are doing. I have a nice day ahead of the individual named recipient
Dear sir
My phone huawei G510 runs but the display light is not coming please can u give me some suggestion how to repair it
sak - Yanıt
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 6
Son 30 Gün: 27
Her zaman: 4,554
