Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
If your ear speaker on your Huawei Ascend G610 is broken, follow this guide.
  1. Remove the back cover.
    • Remove the back cover.
  2. Remove the battery.
    • Remove the battery.
  3. With a cross-head screwdriver remove 9 side screws that secure the back case. Remove the adhesive to find the underlying screw. Remove the shortest central screw near the SIM card slot.
    • With a cross-head screwdriver remove 9 side screws that secure the back case.
    • Remove the adhesive to find the underlying screw.
    • Remove the shortest central screw near the SIM card slot.
    • With the help of a thin tool, pry open the back case.
  4. LCD iPhone Ekran Tamir Kit'leri
    Ömür Boyu Garantimiz kapsamındaki bütçe seçeneği.
    Shop Kits
    Onarım maliyetlerini düşürün, kaliteyi değil.
    Shop Kits
  5. Remove the display connector.
    • Remove the display connector.
  6. Remove the touch screen digitizer connector.
    • Remove the touch screen digitizer connector.
  7. Remove the ambient light sensor connector.
    • Remove the ambient light sensor connector.
  8. Unplug the connector that joins the main motherboard with the dock.
    • Unplug the connector that joins the main motherboard with the dock.
  9. Unplug the motherboard securely fastened at 3 points and remove it. Unplug the motherboard securely fastened at 3 points and remove it. Unplug the motherboard securely fastened at 3 points and remove it.
    • Unplug the motherboard securely fastened at 3 points and remove it.
  10. With the help of a heat source to loosen the adhesive, remove the broken ear speaker and replace it with the new one. With the help of a heat source to loosen the adhesive, remove the broken ear speaker and replace it with the new one.
    • With the help of a heat source to loosen the adhesive, remove the broken ear speaker and replace it with the new one.
Sonuç
To reassemble the device, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Smilzo
6.033 İtibar
35 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 1,241
