Ana içeriğe geç
Huawei Ascend G7 Display Assembly Replacement
Neye ihtiyacın var
  1. Huawei Ascend G7 Display Assembly Replacement, Remove upper frame casing: adım 1, 3 resimden 1. Huawei Ascend G7 Display Assembly Replacement, Remove upper frame casing: adım 1, 3 resimden 2. Huawei Ascend G7 Display Assembly Replacement, Remove upper frame casing: adım 1, 3 resimden 3.
    • Under the top frame there are 3 screws. The frame is glued. Heat without exaggerating the frame and lever to disengage.
  2. Huawei Ascend G7 Display Assembly Replacement, Remove the 3 screws: adım 2, 1 resimden 1.
    • Remove the 3 screws
  3. Huawei Ascend G7 Display Assembly Replacement, Removing lower frame casing: adım 3, 3 resimden 1. Huawei Ascend G7 Display Assembly Replacement, Removing lower frame casing: adım 3, 3 resimden 2. Huawei Ascend G7 Display Assembly Replacement, Removing lower frame casing: adım 3, 3 resimden 3.
    • Under the Lower frame there are three screws. The frame is glued. Heat without exaggerating the frame and lever to disengage.
    • This is the same as removing as removing the upper frame casing
  4. Huawei Ascend G7 Display Assembly Replacement, Removing the screws of the lower casing: adım 4, 1 resimden 1.
    • Removing the 3 screws
  5. Huawei Ascend G7 Display Assembly Replacement, Remove the sim and sd card: adım 5, 1 resimden 1.
    • Remove the door of Sim
    • Remove the cover of the SD Card.
  6. Huawei Ascend G7 Display Assembly Replacement, Removing the bottom: adım 6, 3 resimden 1. Huawei Ascend G7 Display Assembly Replacement, Removing the bottom: adım 6, 3 resimden 2. Huawei Ascend G7 Display Assembly Replacement, Removing the bottom: adım 6, 3 resimden 3.
    • Use a prying tool to pry the display away from the back case.
    • Be careful not to lose the volume buttons and the power button.
  7. Huawei Ascend G7 Display Assembly Replacement: adım 7, 1 resimden 1.
    • The disassembled smartphone with the aluminum back removed
  8. Huawei Ascend G7 Display Assembly Replacement, Removal Of Battery: adım 8, 2 resimden 1. Huawei Ascend G7 Display Assembly Replacement, Removal Of Battery: adım 8, 2 resimden 2.
    • Disconnect the battery connector.
    • If The battery is stuck, remove it very carefully.
  9. Huawei Ascend G7 Display Assembly Replacement, Disconnect video connector: adım 9, 2 resimden 1. Huawei Ascend G7 Display Assembly Replacement, Disconnect video connector: adım 9, 2 resimden 2.
    • Disconnect the video connector gently.
  10. Huawei Ascend G7 Display Assembly Replacement, Headphone Connector: adım 10, 1 resimden 1.
    • Gently unplug the headphone connector.
  11. Huawei Ascend G7 Display Assembly Replacement, Remove screw: adım 11, 2 resimden 1. Huawei Ascend G7 Display Assembly Replacement, Remove screw: adım 11, 2 resimden 2.
    • Remove the screw at the bottom.
  12. Huawei Ascend G7 Display Assembly Replacement, Remove the screw: adım 12, 2 resimden 1. Huawei Ascend G7 Display Assembly Replacement, Remove the screw: adım 12, 2 resimden 2.
    • Remove screw from the top
  13. Huawei Ascend G7 Display Assembly Replacement, Remove the screw: adım 13, 2 resimden 1. Huawei Ascend G7 Display Assembly Replacement, Remove the screw: adım 13, 2 resimden 2.
    • Remove the screw next to the video connector.
    • Your almost to the finish line! Just 3 more steps to go.
  14. Huawei Ascend G7 Display Assembly Replacement, Mainboard: adım 14, 1 resimden 1.
    • Gently rotate outside the motherboard, making sure not to break the little indicated connector
  15. Huawei Ascend G7 Display Assembly Replacement, Connector: adım 15, 2 resimden 1. Huawei Ascend G7 Display Assembly Replacement, Connector: adım 15, 2 resimden 2.
    • If your new display assembly comes with this ribbon cable already installed, disconnect the old one now.
    • If not, separate this part from the old display and transfer it to the new one.
  16. Huawei Ascend G7 Display Assembly Replacement, Removal of the display and the touch screen: adım 16, 2 resimden 1. Huawei Ascend G7 Display Assembly Replacement, Removal of the display and the touch screen: adım 16, 2 resimden 2.
    • Heat the front.
    • Using a plastic tool to separate the lock display / touch screen from the main body.
  17. Huawei Ascend G7 Display Assembly Replacement: adım 17, 1 resimden 1.
    • You have completed the repair.
Sonuç
36 farklı kişi bu kılavuzu tamamladı.
Andrea Murinu
948 İtibar
1 Kılavuz yazıldı
4 Yorum
donde puedo conseguir el remplazo de la pantalla completa, LCD + touch?
mnemcf95 - Yanıt
Hi , thanks this info is great . My G7 has a broken touch screen but works fine . I have seen replacement screens and units which include the digiboard ? So do I need to still remove the pcb or just the frame to get to the edge of the touch screen ? is it easy to replace the touch sreen alone ? look forward to your reply . Regards Carl.
carl anthony - Yanıt
Step 8 - the battery stock very much, I inserted a credit card in between the casing and the battery to detach it. I guess that bending the battery is very dangerous!
Step 15 - This part means the black flat cable with the three buttons ;-)
Step 16 - The new display needed a small film of glue
pacman0 - Yanıt
Hi, the power on connector on my main board has the plastic clip missing is there a way I can connect them together, they seem too small for soldering.
Andrina - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 21,421
