Aletler
Parçalar
Disconnect all connected devices (such as headphones and USB chargers).
Turn the device off.
Turn the device around.
On the same side as the powerbutton is a little notch. Using it you will have to carefully remove the back cover.
Use a small prying tool if you can't do this with your fingers.
Neredeyse bitti!
Follow the steps in reverse order to reassemble your device.
Sonuç
Bu çevirmenlere özel teşekkürler:
100%
Alex Niculescu dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
