Ana içeriğe geç
Huawei Ascend W1 Rear Camera Lens Replacement
Neye ihtiyacın var
  1. Huawei Ascend W1 Rear Camera Lens Replacement, The phone's orientation.: adım 1, 1 resimden 1.
    • Flip the device over so that the back of the phone is facing you and the screen is against your palm.
  2. Huawei Ascend W1 Rear Camera Lens Replacement, Removing the back cover.: adım 2, 1 resimden 1.
    • Locate the slit at the bottom of the back cover.
    • Using your fingernail, lift up on the back cover to expose the battery.
  3. Huawei Ascend W1 Rear Camera Lens Replacement: adım 3, 1 resimden 1.
    • Lift the back cover off the phone.
    • The back cover is snapped onto the phone so you will feel it unsnapping as you remove it.
  4. Huawei Ascend W1 Rear Camera Lens Replacement, Removing the battery.: adım 4, 3 resimden 1. Huawei Ascend W1 Rear Camera Lens Replacement, Removing the battery.: adım 4, 3 resimden 2. Huawei Ascend W1 Rear Camera Lens Replacement, Removing the battery.: adım 4, 3 resimden 3.
    • Find the indented notch at the base of the battery.
    • Lift the battery out of the phone with your fingers by pressing forward and lifting upward.
  5. Huawei Ascend W1 Rear Camera Lens Replacement, Rear Camera Lens: adım 5, 2 resimden 1. Huawei Ascend W1 Rear Camera Lens Replacement, Rear Camera Lens: adım 5, 2 resimden 2.
    • After removing the battery, remove the 2mm screws using a T5 Torx screwdriver.
    • There are eleven screws that hold the middle cover to the rest of the phone.
  6. Huawei Ascend W1 Rear Camera Lens Replacement: adım 6, 2 resimden 1. Huawei Ascend W1 Rear Camera Lens Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to gently press against the back of the lens from the back of the frame.
    • Use tweezers to pry off the lens from the front of the frame.
Sonuç
Tanner Cline
169 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G2, Harley Fall 2018 IUPUI, Team S3-G2, Harley Fall 2018 üyesi
IUPUI-HARLEY-F18S3G2
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 146
