Ana içeriğe geç
Huawei H881C Screen Replacement Replacement
Neye ihtiyacın var
  1. Huawei H881C Screen Replacement Replacement, Screen Replacement: adım 1, 2 resimden 1. Huawei H881C Screen Replacement Replacement, Screen Replacement: adım 1, 2 resimden 2.
    • This is where we begin! At the bottom of the phone, pull the plastic back cover off.
    • Ahh, the battery. Simply pull the battery up and out of the housing.
  2. Huawei H881C Screen Replacement Replacement: adım 2, 1 resimden 1.
    • 8x T5 torx screws are what we need to remove next. There is one hiding below a black sticker. WARNING: This will void your warranty!
  3. Huawei H881C Screen Replacement Replacement: adım 3, 3 resimden 1. Huawei H881C Screen Replacement Replacement: adım 3, 3 resimden 2. Huawei H881C Screen Replacement Replacement: adım 3, 3 resimden 3.
    • Now that the screws are removed, grab a spudger tool or a thick guitar pick. Start at the volume rocker and work your way around the phone by carefully pulling back the frame.
  4. Huawei H881C Screen Replacement Replacement: adım 4, 3 resimden 1. Huawei H881C Screen Replacement Replacement: adım 4, 3 resimden 2. Huawei H881C Screen Replacement Replacement: adım 4, 3 resimden 3.
    • We're inside! At this step, there are 3 ribbon cables we need to disconnect to continue. Carefully pull these ribbon connections up.
  5. Huawei H881C Screen Replacement Replacement: adım 5, 2 resimden 1. Huawei H881C Screen Replacement Replacement: adım 5, 2 resimden 2.
    • Under the screen/digitizer connection, there is one more cable. Carefully disconnect this one was well.
    • Remove the camera by pulling straight up.
  6. Huawei H881C Screen Replacement Replacement: adım 6, 3 resimden 1. Huawei H881C Screen Replacement Replacement: adım 6, 3 resimden 2. Huawei H881C Screen Replacement Replacement: adım 6, 3 resimden 3.
    • Don't mind the ugly "circles". What is circled is the clips you need to pull back to remove the motherboard from the frame.
    • Your fingernail will work perfect for this.
    • Let's remove the motherboard. With your right hand, slowly pull back the motherboard. With you left hand, guide the ribbon cable through the hole to avoid damaging it.
  7. Huawei H881C Screen Replacement Replacement: adım 7, 3 resimden 1. Huawei H881C Screen Replacement Replacement: adım 7, 3 resimden 2. Huawei H881C Screen Replacement Replacement: adım 7, 3 resimden 3.
    • Now that the motherboard is out, this is the screen/digitizer/LCD assembly. From here, we need to only remove the digitizer.
    • We recommend using a heat gun or a hot plate if you have one. If you don't have either, use a blow dryer!
  8. Huawei H881C Screen Replacement Replacement: adım 8, 3 resimden 1. Huawei H881C Screen Replacement Replacement: adım 8, 3 resimden 2. Huawei H881C Screen Replacement Replacement: adım 8, 3 resimden 3.
    • After its hot enough, use a thick guitar pick to peel back the broken screen from the frame. Be careful, it may be hot and glass could get everywhere.
    • Once you've removed the old screen/digitizer, apply new adhesive on the frame and put the new part on. Make sure that you get the old adhesive peeled off. We recommend heating the adhesive before applying the new screen for better bonding.
    • That's it! Now, follow the steps backwards to reassemble your device. Congrats! You've replaced the screen!
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
GadgetERService
1.650 İtibar
2 adet Kılavuz yazıldı
Ekip
Minnesota Repair Techs Minnesota Repair Techs üyesi
Community
3 Üyeler
2 Yorum
what do you use as an adheasive?
Randy Edwards - Yanıt
Randy, I'm extremely late responding to your post. I use what the industry calls, "red tape". This stuff is perfect for pretty much any electronic repair, especially iPads.
GadgetERService -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 19,524
