Ana içeriğe geç
Huawei Honor 20 lite battery Replacement
Neye ihtiyacın var
  1. Huawei Honor 20 lite battery Replacement, heating back cover: adım 1, 1 resimden 1.
    • Place phone on a heating bed.
    • I set it to 80 degrees celcius and left it on there for 5 minutes.
  2. Huawei Honor 20 lite battery Replacement, removing the back cover: adım 2, 1 resimden 1.
    • once the glue is softened, use the plastic pick tool to loosen one edge.
    • leave a pick under one side to stop that side from re-sticking as you move onto the next edge.
  3. Huawei Honor 20 lite battery Replacement, undoing the screws: adım 3, 2 resimden 1. Huawei Honor 20 lite battery Replacement, undoing the screws: adım 3, 2 resimden 2.
    • place the back cover side by side with the rest of he phone. being careful a the fingerprint scanner cable is on the back of the phone
    • take out all the screws in the bottom part of the phone and gently lift off, away from the phone.
    • unclip the ribbon cable.
  4. Huawei Honor 20 lite battery Replacement, top screws: adım 4, 1 resimden 1.
    • next repeat the same process along the top part. (be careful with the cameras, the cover should just unclip without much effort.)
    • be careful of the 2 screws circled. these need to come out as well.
  5. Huawei Honor 20 lite battery Replacement, pulling battery tabs: adım 5, 2 resimden 1. Huawei Honor 20 lite battery Replacement, pulling battery tabs: adım 5, 2 resimden 2.
    • gently pry the battery terminal away from the board
    • next pull tab 1 and 2 individually.
  6. Huawei Honor 20 lite battery Replacement, battery removal: adım 6, 1 resimden 1.
    • when you pull tab 3, the battery should hinge away from you and then pull towards you .
    • insert a new battery and repeat the steps backwards.
Sonuç
Bir başkası bu kılavuzu tamamladı.
chris dodds
145 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 47
Son 30 gün: 70
Her zaman: 894
