Ana içeriğe geç
Huawei Honor 5X Volume and Power Buttons Replacement
Neye ihtiyacın var
  1. Huawei Honor 5X Volume and Power Buttons Replacement, HUAWEI HONOR 5X Disassembly: adım 1, 1 resimden 1.
    • Turn off your cell phone before disassembling.
  2. Huawei Honor 5X Volume and Power Buttons Replacement: adım 2, 1 resimden 1.
    • Remove the two 1.17mm Torx T3 screws from the bottom of the phone.
  3. Huawei Honor 5X Volume and Power Buttons Replacement: adım 3, 2 resimden 1. Huawei Honor 5X Volume and Power Buttons Replacement: adım 3, 2 resimden 2.
    • Use the Sim card ejection tool to remove both the sim card trays.
  4. Huawei Honor 5X Volume and Power Buttons Replacement: adım 4, 1 resimden 1.
    • To prepare the iOpener insert it in the microwave for 30 seconds and apply it on the side edges of the phone so that the glue underneath will soften.
  5. Huawei Honor 5X Volume and Power Buttons Replacement: adım 5, 2 resimden 1. Huawei Honor 5X Volume and Power Buttons Replacement: adım 5, 2 resimden 2.
    • Pry off the back with a plastic opening tool.
  6. Huawei Honor 5X Volume and Power Buttons Replacement, Battery: adım 6, 1 resimden 1.
    • Remove the pink sticker.
  7. Huawei Honor 5X Volume and Power Buttons Replacement: adım 7, 1 resimden 1.
    • Remove the three 1.5mm Phillips #000 screws.
  8. Huawei Honor 5X Volume and Power Buttons Replacement: adım 8, 2 resimden 1. Huawei Honor 5X Volume and Power Buttons Replacement: adım 8, 2 resimden 2.
    • Use a plastic opening tool to disconnect the orange and black battery cables from the motherboard.
  9. Huawei Honor 5X Volume and Power Buttons Replacement: adım 9, 1 resimden 1.
    • Remove the battery from the phone.
  10. Huawei Honor 5X Volume and Power Buttons Replacement, Motherboard: adım 10, 2 resimden 1. Huawei Honor 5X Volume and Power Buttons Replacement, Motherboard: adım 10, 2 resimden 2.
    • Remove the five 1.5mm Phillips #000 screws from the motherboard.
  11. Huawei Honor 5X Volume and Power Buttons Replacement: adım 11, 2 resimden 1. Huawei Honor 5X Volume and Power Buttons Replacement: adım 11, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use a plastic opening tool to pry up and disconnect the display cable from the motherboard.
    • Use tweezers to disconnect the white coax cable.
    • Use tweezers to disconnect the power and volume cable.
  12. Huawei Honor 5X Volume and Power Buttons Replacement: adım 12, 3 resimden 1. Huawei Honor 5X Volume and Power Buttons Replacement: adım 12, 3 resimden 2. Huawei Honor 5X Volume and Power Buttons Replacement: adım 12, 3 resimden 3.
    • Remove the motherboard.
  13. Huawei Honor 5X Volume and Power Buttons Replacement, Volume and Power Buttons: adım 13, 2 resimden 1. Huawei Honor 5X Volume and Power Buttons Replacement, Volume and Power Buttons: adım 13, 2 resimden 2.
    Satın Al
    • Use the tweezers to pull the button assembly from the small black clips on the back plate of the phone.
Sonuç
Eric Petrous
145 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G4, Hovde Fall 2019 IUPUI, Team S1-G4, Hovde Fall 2019 üyesi
IUPUI-HOVDE-F19S1G4
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 919
