Ana içeriğe geç
Huawei Honor 6x Front Camera Replacement
Neye ihtiyacın var
  1. Huawei Honor 6x Front Camera  Replacement, SIM Card: adım 1, 1 resimden 1.
    • Turn off the device.
    FixBot'a Sor
    Yorum Ekle
  2. Huawei Honor 6x Front Camera  Replacement: adım 2, 2 resimden 1. Huawei Honor 6x Front Camera  Replacement: adım 2, 2 resimden 2.
    • Insert the SIM Card Eject Tool into the SIM card tray hole.
    • Press the eject tool into the hole until the tray clicks open.
    FixBot'a Sor
    Yorum Ekle
  3. Huawei Honor 6x Front Camera  Replacement: adım 3, 1 resimden 1.
    • Remove the SIM tray from the device using two fingers.
    • When reinserting the SIM card, be sure it is properly aligned with the SIM tray.
    FixBot'a Sor
    Yorum Ekle
  4. Huawei Honor 6x Front Camera  Replacement: adım 4, 1 resimden 1.
    • Remove the SIM card from the compartment using two fingers.
    FixBot'a Sor
    Yorum Ekle
  5. Huawei Honor 6x Front Camera  Replacement, Back Cover: adım 5, 2 resimden 1. Huawei Honor 6x Front Camera  Replacement, Back Cover: adım 5, 2 resimden 2.
    • Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
    • Pry the screen off the back of the phone by pushing down on the opening tool.
    FixBot'a Sor
    Yorum Ekle
  6. Huawei Honor 6x Front Camera  Replacement: adım 6, 3 resimden 1. Huawei Honor 6x Front Camera  Replacement: adım 6, 3 resimden 2. Huawei Honor 6x Front Camera  Replacement: adım 6, 3 resimden 3.
    • Slide the opening tool or spudger along the bottom of the phone and around the edge.
    FixBot'a Sor
    Yorum Ekle
  7. Huawei Honor 6x Front Camera  Replacement: adım 7, 2 resimden 1. Huawei Honor 6x Front Camera  Replacement: adım 7, 2 resimden 2.
    • Once three sides of the screen are detached, pry the phone apart using two hands.
    • When separating the back panel from the screen, do not pull them too far apart. There is an interconnect that is attached to both sides that could break, or tear, if pulled too far.
    FixBot'a Sor
    Yorum Ekle
  8. Huawei Honor 6x Front Camera  Replacement: adım 8, 3 resimden 1. Huawei Honor 6x Front Camera  Replacement: adım 8, 3 resimden 2. Huawei Honor 6x Front Camera  Replacement: adım 8, 3 resimden 3.
    • Remove the five 4mm Phillips #00 screws using a screwdriver.
    FixBot'a Sor
    Yorum Ekle
  9. Huawei Honor 6x Front Camera  Replacement: adım 9, 1 resimden 1.
    • Remove the motherboard cover from the device using a spudger or your fingers.
    FixBot'a Sor
    Yorum Ekle
  10. Huawei Honor 6x Front Camera  Replacement, Front Camera: adım 10, 3 resimden 1. Huawei Honor 6x Front Camera  Replacement, Front Camera: adım 10, 3 resimden 2. Huawei Honor 6x Front Camera  Replacement, Front Camera: adım 10, 3 resimden 3.
    • Pry the seven connectors off using a spudger or your finger.
    FixBot'a Sor
    Yorum Ekle
  11. Huawei Honor 6x Front Camera  Replacement: adım 11, 3 resimden 1. Huawei Honor 6x Front Camera  Replacement: adım 11, 3 resimden 2. Huawei Honor 6x Front Camera  Replacement: adım 11, 3 resimden 3.
    • Remove the four 2 mm Phillips #00 screws.
    FixBot'a Sor
    Yorum Ekle
  12. Huawei Honor 6x Front Camera  Replacement: adım 12, 2 resimden 1. Huawei Honor 6x Front Camera  Replacement: adım 12, 2 resimden 2.
    • Lift the motherboard off of the phone using a spudger or two fingers.
    • The left side of the motherboard has a strip of rubber that may need some prodding from a spudger to remove.
    FixBot'a Sor
    Yorum Ekle
  13. Huawei Honor 6x Front Camera  Replacement: adım 13, 2 resimden 1. Huawei Honor 6x Front Camera  Replacement: adım 13, 2 resimden 2.
    • Remove the cable connecting the camera from the motherboard using a spudger or your finger.
    FixBot'a Sor
    Yorum Ekle
  14. Huawei Honor 6x Front Camera  Replacement: adım 14, 3 resimden 1. Huawei Honor 6x Front Camera  Replacement: adım 14, 3 resimden 2. Huawei Honor 6x Front Camera  Replacement: adım 14, 3 resimden 3.
    • Remove the front camera out from the motherboard by pushing on it with the tip of a spudger.
    • This is best done from the back side of the motherboard and pushing where the cable meets the camera.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Tessa Kemper
591 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S13-G5, White Fall 2018 Cal Poly, Team S13-G5, White Fall 2018 üyesi
CPSU-WHITE-F18S13G5
4 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 52
Her zaman: 1,517
