Ana içeriğe geç
Giriş
If the front camera on your device is failing or blurry you may need to replace the assembly. This guide will follow you through the steps required to open your device to get to the front camera.
  1. Turn off the device.
    • Turn off the device.
  2. Insert the SIM Card Eject Tool into the SIM card tray hole. Press the eject tool into the hole until the tray clicks open.
    • Insert the SIM Card Eject Tool into the SIM card tray hole.
    • Press the eject tool into the hole until the tray clicks open.
  3. Remove the SIM tray from the device using two fingers.
    • Remove the SIM tray from the device using two fingers.
    • When reinserting the SIM card, be sure it is properly aligned with the SIM tray.
  4. Remove the SIM card from the compartment using two fingers.
    • Remove the SIM card from the compartment using two fingers.
  5. Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen. Pry the screen off the back of the phone by pushing down on the opening tool.
    • Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
    • Pry the screen off the back of the phone by pushing down on the opening tool.
  6. Slide the opening tool or spudger along the bottom of the phone and around the edge. Slide the opening tool or spudger along the bottom of the phone and around the edge. Slide the opening tool or spudger along the bottom of the phone and around the edge.
    • Slide the opening tool or spudger along the bottom of the phone and around the edge.
  7. Once three sides of the  screen are detached, pry the phone apart using two hands. When separating the back panel from the screen, do not pull them too far apart. There is an interconnect that is attached to both sides that could break, or tear, if pulled too far.
    • Once three sides of the screen are detached, pry the phone apart using two hands.
    • When separating the back panel from the screen, do not pull them too far apart. There is an interconnect that is attached to both sides that could break, or tear, if pulled too far.
  8. Remove the five 4mm  Phillips #00 screws using a screwdriver. Remove the five 4mm  Phillips #00 screws using a screwdriver. Remove the five 4mm  Phillips #00 screws using a screwdriver.
    • Remove the five 4mm Phillips #00 screws using a screwdriver.
  9. Remove the motherboard cover from the device using a spudger or your fingers.
    • Remove the motherboard cover from the device using a spudger or your fingers.
  10. Pry the seven connectors off using a spudger or your finger. Pry the seven connectors off using a spudger or your finger. Pry the seven connectors off using a spudger or your finger.
    • Pry the seven connectors off using a spudger or your finger.
  11. Remove the four 2 mm Phillips #00 screws. Remove the four 2 mm Phillips #00 screws. Remove the four 2 mm Phillips #00 screws.
    • Remove the four 2 mm Phillips #00 screws.
  12. Lift the motherboard off of the phone using a spudger or two fingers. The left side of the motherboard has a strip of rubber that may need some prodding from a spudger to remove.
    • Lift the motherboard off of the phone using a spudger or two fingers.
    • The left side of the motherboard has a strip of rubber that may need some prodding from a spudger to remove.
  13. Remove the cable connecting the camera from the motherboard using a spudger or your finger. Remove the cable connecting the camera from the motherboard using a spudger or your finger.
    • Remove the cable connecting the camera from the motherboard using a spudger or your finger.
  14. Remove the front camera out from the motherboard by pushing on it with the tip of a spudger. This is best done from the back side of the motherboard and pushing where the cable meets the camera. This is best done from the back side of the motherboard and pushing where the cable meets the camera.
    • Remove the front camera out from the motherboard by pushing on it with the tip of a spudger.
    • This is best done from the back side of the motherboard and pushing where the cable meets the camera.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Tessa Kemper
549 İtibar
3 adet Kılavuz yazıldı
Takım
Cal Poly, Team S13-G5, White Fall 2018 Cal Poly, Team S13-G5, White Fall 2018 üyesi
CPSU-WHITE-F18S13G5
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 512
