Ana içeriğe geç
Huawei Honor 6x Front Display Panel Replacement
Neye ihtiyacın var
  1. Huawei Honor 6x Front Display Panel Replacement, SIM Card: adım 1, 1 resimden 1.
    • Turn off the device.
    FixBot'a Sor
    Yorum Ekle
  2. Huawei Honor 6x Front Display Panel Replacement: adım 2, 2 resimden 1. Huawei Honor 6x Front Display Panel Replacement: adım 2, 2 resimden 2.
    • Insert the SIM Card Eject Tool into the SIM card tray hole.
    • Press the eject tool into the hole until the tray clicks open.
    FixBot'a Sor
    Yorum Ekle
  3. Huawei Honor 6x Front Display Panel Replacement: adım 3, 1 resimden 1.
    • Remove the SIM tray from the device using two fingers.
    • When reinserting the SIM card, be sure it is properly aligned with the SIM tray.
    FixBot'a Sor
    Yorum Ekle
  4. Huawei Honor 6x Front Display Panel Replacement: adım 4, 1 resimden 1.
    • Remove the SIM card from the compartment using two fingers.
    FixBot'a Sor
    Yorum Ekle
  5. Huawei Honor 6x Front Display Panel Replacement, Back Cover: adım 5, 2 resimden 1. Huawei Honor 6x Front Display Panel Replacement, Back Cover: adım 5, 2 resimden 2.
    • Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
    • Pry the screen off the back of the phone by pushing down on the opening tool.
    FixBot'a Sor
    Yorum Ekle
  6. Huawei Honor 6x Front Display Panel Replacement: adım 6, 3 resimden 1. Huawei Honor 6x Front Display Panel Replacement: adım 6, 3 resimden 2. Huawei Honor 6x Front Display Panel Replacement: adım 6, 3 resimden 3.
    • Slide the opening tool or spudger along the bottom of the phone and around the edge.
    FixBot'a Sor
    Yorum Ekle
  7. Huawei Honor 6x Front Display Panel Replacement: adım 7, 2 resimden 1. Huawei Honor 6x Front Display Panel Replacement: adım 7, 2 resimden 2.
    • Once three sides of the screen are detached, pry the phone apart using two hands.
    • When separating the back panel from the screen, do not pull them too far apart. There is an interconnect that is attached to both sides that could break, or tear, if pulled too far.
    FixBot'a Sor
    Yorum Ekle
  8. Huawei Honor 6x Front Display Panel Replacement: adım 8, 3 resimden 1. Huawei Honor 6x Front Display Panel Replacement: adım 8, 3 resimden 2. Huawei Honor 6x Front Display Panel Replacement: adım 8, 3 resimden 3.
    • Remove the five 4mm Phillips #00 screws using a screwdriver.
    FixBot'a Sor
    Yorum Ekle
  9. Huawei Honor 6x Front Display Panel Replacement: adım 9, 1 resimden 1.
    • Remove the motherboard cover from the device using a spudger or your fingers.
    FixBot'a Sor
    Yorum Ekle
  10. Huawei Honor 6x Front Display Panel Replacement, Battery: adım 10, 2 resimden 1. Huawei Honor 6x Front Display Panel Replacement, Battery: adım 10, 2 resimden 2.
    • Remove the four connectors by placing the spudger between the motherboard and the connectors.
    • Press upwards against the connectors until they disconnect.
    • The connectors will make a "click" sound when disconnected.
    FixBot'a Sor
    Yorum Ekle
  11. Huawei Honor 6x Front Display Panel Replacement: adım 11, 2 resimden 1. Huawei Honor 6x Front Display Panel Replacement: adım 11, 2 resimden 2.
    • Remove the battery by first prying a spudger between the battery and the screen.
    • Slice through the adhesive by pushing card around and underneath the battery.
    • The adhesive is fairly strong, so make sure to press firmly against the adhesive.
    • Do not excessively bend the battery. Bending the battery too much can cause it to break and even catch fire.
    FixBot'a Sor
    Yorum Ekle
  12. Huawei Honor 6x Front Display Panel Replacement: adım 12, 2 resimden 1. Huawei Honor 6x Front Display Panel Replacement: adım 12, 2 resimden 2.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    • Using the plastic card, remove the battery by lifting it from the casing.
    FixBot'a Sor
    Yorum Ekle
  13. Huawei Honor 6x Front Display Panel Replacement, Front Display Panel: adım 13, 2 resimden 1. Huawei Honor 6x Front Display Panel Replacement, Front Display Panel: adım 13, 2 resimden 2.
    • Remove the last two connectors from the motherboard using a spudger or your fingers.
    • All cables should now be detached from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  14. Huawei Honor 6x Front Display Panel Replacement: adım 14, 3 resimden 1. Huawei Honor 6x Front Display Panel Replacement: adım 14, 3 resimden 2. Huawei Honor 6x Front Display Panel Replacement: adım 14, 3 resimden 3.
    • Remove the four 2mm Phillips #00 screws.
    FixBot'a Sor
    Yorum Ekle
  15. Huawei Honor 6x Front Display Panel Replacement: adım 15, 2 resimden 1. Huawei Honor 6x Front Display Panel Replacement: adım 15, 2 resimden 2.
    • Gently lift the motherboard from the phone using two fingers or a spudger.
    FixBot'a Sor
    Yorum Ekle
  16. Huawei Honor 6x Front Display Panel Replacement: adım 16, 1 resimden 1.
    • Remove the speaker using the tip of a spudger.
    • The speaker may need to be re-glued during reassembly.
    FixBot'a Sor
    Yorum Ekle
  17. Huawei Honor 6x Front Display Panel Replacement: adım 17, 3 resimden 1. Huawei Honor 6x Front Display Panel Replacement: adım 17, 3 resimden 2. Huawei Honor 6x Front Display Panel Replacement: adım 17, 3 resimden 3.
    • Remove the five 2mm Phillips #00 screws using a screwdriver.
    • Remove the two 2mm #5 Torx screws using a screwdriver.
    FixBot'a Sor
    Yorum Ekle
  18. Huawei Honor 6x Front Display Panel Replacement: adım 18, 2 resimden 1. Huawei Honor 6x Front Display Panel Replacement: adım 18, 2 resimden 2.
    • Remove the metal plate from the vibrator assembly using a spudger.
    FixBot'a Sor
    Yorum Ekle
  19. Huawei Honor 6x Front Display Panel Replacement: adım 19, 3 resimden 1. Huawei Honor 6x Front Display Panel Replacement: adım 19, 3 resimden 2. Huawei Honor 6x Front Display Panel Replacement: adım 19, 3 resimden 3.
    • Snap the two connectors off using a spudger or your finger.
    FixBot'a Sor
    Yorum Ekle
  20. Huawei Honor 6x Front Display Panel Replacement: adım 20, 1 resimden 1.
    • Pry the micro USB port off of the phone using a spudger.
    FixBot'a Sor
    Yorum Ekle
  21. Huawei Honor 6x Front Display Panel Replacement: adım 21, 3 resimden 1. Huawei Honor 6x Front Display Panel Replacement: adım 21, 3 resimden 2. Huawei Honor 6x Front Display Panel Replacement: adım 21, 3 resimden 3.
    • Pry the speaker and microphone assembly off of the phone by sliding a spudger down along the bottom.
    FixBot'a Sor
    Yorum Ekle
  22. Huawei Honor 6x Front Display Panel Replacement: adım 22, 2 resimden 1. Huawei Honor 6x Front Display Panel Replacement: adım 22, 2 resimden 2.
    • Pull the volume buttons off using tweezers or the end of a spudger.
    • It may take a bit of wiggling and poking to get through the adhesive.
    FixBot'a Sor
    Yorum Ekle
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Tessa Kemper
591 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S13-G5, White Fall 2018 Cal Poly, Team S13-G5, White Fall 2018 üyesi
CPSU-WHITE-F18S13G5
4 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 71
Her zaman: 5,864
