Giriş
If the camera of your Huawei Honor 6x is inoperable and the problem is not due to a cracked cover, the rear camera will need to be replaced. Removing the broken camera assembly is simple and easy after opening the phone.
Neye ihtiyacın var
Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
Pry the screen off the back of the phone by pushing down on the opening tool.
Pry the two connectors off by wedging a spudger, or your finger, underneath the connector.
2 farklı kişi bu kılavuzu tamamladı.
