Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Huawei Honor 8 Motherboard Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Huawei Honor 8 Motherboard Replacement, Rear Glass & Frame: adım 1, 1 resimden 1.
    • Make sure you spend at least 5 minutes heating up the adhesive. Prying off the glass cover too early can result in cracking the panel.
    • Using a heat gun or hairdryer, apply heat approximately three inches above the glass panel to warm up the adhesive around the outside edge of the phone.
    • Make sure to apply heat evenly across the outside edge of the device.
  2. Huawei Honor 8 Motherboard Replacement: adım 2, 2 resimden 1. Huawei Honor 8 Motherboard Replacement: adım 2, 2 resimden 2.
    • Be careful not to tear the orange ribbon wire when removing the back panel.
    • Using a plastic opening tool, gently pry up a corner of the rear glass panel.
    • Slowly slide the plastic opening tool around the outside of the glass panel to break through the adhesive.
    • Additional plastic opening tools can be used to help separate the back panel from the phone body.
    • Gently lift the back panel off once all the adhesive has been removed.
  3. Huawei Honor 8 Motherboard Replacement: adım 3, 3 resimden 1. Huawei Honor 8 Motherboard Replacement: adım 3, 3 resimden 2. Huawei Honor 8 Motherboard Replacement: adım 3, 3 resimden 3.
    • Using a Phillips PH00 screwdriver, remove the silver Phillips 3.5 mm screw circled in red.
    • Using a spudger, gently lift off the small metal tab that was held in place by the screw.
    • Gently pry off the orange ribbon wire on the back panel.
  4. Huawei Honor 8 Motherboard Replacement: adım 4, 1 resimden 1.
    • Keep the tiny screws on a magnetic pad or a designated area so they will not be lost. There are eighteen screws in total.
    • Using a Phillips PH00 screwdriver, remove the eight silver Phillips 3.5 mm screws circled in red.
    • Using a Phillips PH00 screwdriver, remove the six black Phillips 4.0 mm screws circled in orange.
    • Using a Phillips PH00 screwdriver, remove the single silver 3.0 mm Phillips screw circled in yellow.
    • Using the Phillips PH00 screwdriver tip, gently scratch away the white stickers outlined in green circles to expose hidden screws.
    • Using a Phillips PH00 screwdriver, remove the two black Phillips 4.0 mm screws circled in green.
  5. Huawei Honor 8 Motherboard Replacement: adım 5, 3 resimden 1. Huawei Honor 8 Motherboard Replacement: adım 5, 3 resimden 2. Huawei Honor 8 Motherboard Replacement: adım 5, 3 resimden 3.
    • Slowly slide the plastic opening tool around the perimeter of the inner lining.
    • Additional plastic opening tools can be used to help separate the inner lining from the phone body.
    • Gently pull the inner lining up to remove it from the phone body.
  6. Huawei Honor 8 Motherboard Replacement, Motherboard: adım 6, 3 resimden 1. Huawei Honor 8 Motherboard Replacement, Motherboard: adım 6, 3 resimden 2. Huawei Honor 8 Motherboard Replacement, Motherboard: adım 6, 3 resimden 3.
    • Holding the phone so that the cameras are at the top, locate the small hole on the top right edge of the device.
    • Using the 0.8 mm Sim Eject tool, push down on the small hole to release the Sim Card tray.
    • Gently pull out the Sim Card tray and set it aside.
  7. Huawei Honor 8 Motherboard Replacement: adım 7, 1 resimden 1.
    • In the following steps you will disconnect the five connectors circled in red holding the motherboard in place.
  8. Huawei Honor 8 Motherboard Replacement: adım 8, 2 resimden 1. Huawei Honor 8 Motherboard Replacement: adım 8, 2 resimden 2.
    • Gently pull the small ribbon connection between the battery and motherboard upward to disconnect it.
    • Use a spudger to help pry off the connection if necessary.
  9. Huawei Honor 8 Motherboard Replacement: adım 9, 1 resimden 1.
    • Use a spudger to gently pry off the small antenna cable on the right side of the motherboard.
  10. Huawei Honor 8 Motherboard Replacement: adım 10, 2 resimden 1. Huawei Honor 8 Motherboard Replacement: adım 10, 2 resimden 2.
    • Using a spudger, gently pry up the small connection that holds the motherboard in place.
  11. Huawei Honor 8 Motherboard Replacement: adım 11, 1 resimden 1.
    • Using a spudger, gently pry up the connector near the left edge of the motherboard.
  12. Huawei Honor 8 Motherboard Replacement: adım 12, 1 resimden 1.
    • Use a spudger to gently pry off the small connection on the far left edge of the motherboard.
  13. Huawei Honor 8 Motherboard Replacement: adım 13, 2 resimden 1. Huawei Honor 8 Motherboard Replacement: adım 13, 2 resimden 2.
    • Use a spudger to pry up a corner of the motherboard.
    • Lift the motherboard to remove it from the body of the phone.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Jaret Wedow
1.752 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G2, Forte Fall 2017 Cal Poly, Team S18-G2, Forte Fall 2017 üyesi
CPSU-FORTE-F17S18G2
4 Üyeler
24 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 38
Her zaman: 7,414
