Ana içeriğe geç
Huawei Ideos S7 Slim Touchscreen Replacement
Neye ihtiyacın var
  1. Huawei Ideos S7 Slim Touchscreen Replacement, Battery: adım 1, 3 resimden 1. Huawei Ideos S7 Slim Touchscreen Replacement, Battery: adım 1, 3 resimden 2. Huawei Ideos S7 Slim Touchscreen Replacement, Battery: adım 1, 3 resimden 3.
    • Place the tablet on a flat clear surface to keep the screen safe.
    • Slide the larger portion of the back cover off the tablet.
    • This will reveal the battery.
  2. Huawei Ideos S7 Slim Touchscreen Replacement: adım 2, 2 resimden 1. Huawei Ideos S7 Slim Touchscreen Replacement: adım 2, 2 resimden 2.
    • Lift the battery out with your finger.
    • Make sure you use the slot near the bottom of the device as shown. Trying to lift from anywhere else will not work and may damage the battery or the device.
  3. Huawei Ideos S7 Slim Touchscreen Replacement, Logic Board: adım 3, 2 resimden 1. Huawei Ideos S7 Slim Touchscreen Replacement, Logic Board: adım 3, 2 resimden 2.
    • Using a plastic opening tool, pry off the top cover casing gently by moving the tool along all three sides.
  4. Huawei Ideos S7 Slim Touchscreen Replacement: adım 4, 1 resimden 1.
    • With a T5 hexagonal head, remove the nine black 2.5 mm torx screws. Place them carefully aside on the magnetic mat.
  5. Huawei Ideos S7 Slim Touchscreen Replacement: adım 5, 3 resimden 1. Huawei Ideos S7 Slim Touchscreen Replacement: adım 5, 3 resimden 2. Huawei Ideos S7 Slim Touchscreen Replacement: adım 5, 3 resimden 3.
    • Using a plastic opening tool, pry off the back casing gently on each side of the tablet.
  6. Huawei Ideos S7 Slim Touchscreen Replacement: adım 6, 3 resimden 1. Huawei Ideos S7 Slim Touchscreen Replacement: adım 6, 3 resimden 2. Huawei Ideos S7 Slim Touchscreen Replacement: adım 6, 3 resimden 3.
    • Using a Phillips #00 screwdriver, remove the following screws:
    • Four 5mm wide grey Phillips screws on the logic board.
    • One of the 5mm screws is hidden under the circular white tape in the center of the logic board.
    • Seven 3mm small grey Phillips screws (four on one side, three on the other) from the black side casing.
  7. Huawei Ideos S7 Slim Touchscreen Replacement: adım 7, 3 resimden 1. Huawei Ideos S7 Slim Touchscreen Replacement: adım 7, 3 resimden 2. Huawei Ideos S7 Slim Touchscreen Replacement: adım 7, 3 resimden 3.
    • Disconnect the five cables connected to the logic board and then carefully lift the logic board out of the casing.
  8. Huawei Ideos S7 Slim Touchscreen Replacement, Touchscreen: adım 8, 3 resimden 1. Huawei Ideos S7 Slim Touchscreen Replacement, Touchscreen: adım 8, 3 resimden 2. Huawei Ideos S7 Slim Touchscreen Replacement, Touchscreen: adım 8, 3 resimden 3.
    • Tilt the tablet on its lengthy side, place your thumbs on the side and gently separate the LCD from the touchscreen.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Gregory Philip
585 İtibar
4 adet Kılavuz yazıldı
Ekip
UC Davis, Team 1-1, Oliver Fall 2016 UC Davis, Team 1-1, Oliver Fall 2016 üyesi
UCD-OLIVER-F16S1G1
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 1,324
