Ana içeriğe geç
Huawei M750 Button Replacement
Neye ihtiyacın var
  1. Huawei M750 Button Replacement, Battery: adım 1, 1 resimden 1.
    • Depress the top of the battery cover, and pull downwards towards the base of the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Huawei M750 Button Replacement: adım 2, 1 resimden 1.
    • Remove the battery by levering the battery out, using the cut just below the camera.
    FixBot'a Sor
    Yorum Ekle
  3. Huawei M750 Button Replacement, Back Panel: adım 3, 1 resimden 1.
    • Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
    • Work the opening tool around the border of the camera and speaker cover, until it comes loose.
    FixBot'a Sor
    Yorum Ekle
  4. Huawei M750 Button Replacement: adım 4, 2 resimden 1. Huawei M750 Button Replacement: adım 4, 2 resimden 2.
    • Using the T5 Torx screwdriver, remove the six 6mm screws.
    FixBot'a Sor
    Yorum Ekle
  5. Huawei M750 Button Replacement: adım 5, 2 resimden 1. Huawei M750 Button Replacement: adım 5, 2 resimden 2.
    • Using the opening tool, pry the back panel from the front panel.
    • Work your way around the phone until the panels separate evenly.
    • This step may require a substantial amount of leverage.
    FixBot'a Sor
    Yorum Ekle
  6. Huawei M750 Button Replacement, Buttons: adım 6, 2 resimden 1. Huawei M750 Button Replacement, Buttons: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to grab hold of each button on an edge from inside of the casing and pull out to remove.
    FixBot'a Sor
    Yorum Ekle
  7. Huawei M750 Button Replacement: adım 7, 1 resimden 1.
    • If it is the actual main screen panel control buttons that need to be replaced, grab the front panel as seen in the picture and push from the outside in with little pressure as if you were regularly trying to use the button.
    FixBot'a Sor
    Yorum Ekle
  8. Huawei M750 Button Replacement: adım 8, 2 resimden 1. Huawei M750 Button Replacement: adım 8, 2 resimden 2.
    • If the buttons aren't broken and the phone just isn't getting the signal when the button is depressed, try replacing the actual electronic board under the buttons replaced in the last step.
    • Using the plastic opening tool, insert just under the electronic board and apply slight pressure upward.
    • It is snapped in place so it may seem like you have to add a little more pressure than needed. But don't worry, you won't break the board and it will pop right out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 31
Her zaman: 614
