Ana içeriğe geç
Huawei M750 Camera Replacement
Neye ihtiyacın var
  1. Huawei M750 Camera Replacement, Battery: adım 1, 1 resimden 1.
    • Depress the top of the battery cover, and pull downwards towards the base of the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Huawei M750 Camera Replacement: adım 2, 1 resimden 1.
    • Remove the battery by levering the battery out, using the cut just below the camera.
    FixBot'a Sor
    Yorum Ekle
  3. Huawei M750 Camera Replacement, Back Panel: adım 3, 1 resimden 1.
    • Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
    • Work the opening tool around the border of the camera and speaker cover, until it comes loose.
    FixBot'a Sor
    Yorum Ekle
  4. Huawei M750 Camera Replacement: adım 4, 2 resimden 1. Huawei M750 Camera Replacement: adım 4, 2 resimden 2.
    • Using the T5 Torx screwdriver, remove the six 6mm screws.
    FixBot'a Sor
    Yorum Ekle
  5. Huawei M750 Camera Replacement: adım 5, 2 resimden 1. Huawei M750 Camera Replacement: adım 5, 2 resimden 2.
    • Using the opening tool, pry the back panel from the front panel.
    • Work your way around the phone until the panels separate evenly.
    • This step may require a substantial amount of leverage.
    FixBot'a Sor
    Yorum Ekle
  6. Huawei M750 Camera Replacement, Camera: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • The camera's connection to the motherboard is shown here.
    • Using the tweezers, disconnect the port, shown here in the picture.
    FixBot'a Sor
    Yorum Ekle
  7. Huawei M750 Camera Replacement: adım 7, 1 resimden 1.
    • Using the tweezers, carefully remove the lens and lens casing.
    • It should be held in by a simple tight fit. The front panel is what keeps the lens secured.
    • Do not touch the camera lens, or the digital camera component, if possible. This will prevent scratching, or damage.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 32
Her zaman: 530
