Ana içeriğe geç
Huawei Mate 10 Battery Disconnect
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. Huawei Mate 10 Battery Disconnect, Remove the plastic bracket: adım 1, 2 resimden 1. Huawei Mate 10 Battery Disconnect, Remove the plastic bracket: adım 1, 2 resimden 2.
    • The next two steps show how to remove the heat dissipation layer, along with its plastic bracket.
    • Remove the eight 3.4 mm long Phillips screws securing the plastic bracket.
    • One screw lies beneath a white sticker. Remove the sticker.
    • Insert the point of a spudger underneath the right edge of the plastic bracket and pry up slightly to loosen the shield.
  2. Huawei Mate 10 Battery Disconnect: adım 2, 3 resimden 1. Huawei Mate 10 Battery Disconnect: adım 2, 3 resimden 2. Huawei Mate 10 Battery Disconnect: adım 2, 3 resimden 3.
    • Grasp the the lower edge of the plastic bracket with your fingers and lift the edge up slightly.
    • Pull the plastic bracket away from the top edge of the phone.
    • Slowly peel the black heat dissipation layer away from the phone. It is held in place with small patches of adhesive.
    • Remove the plastic bracket along with the heat dissipation layer.
  3. Huawei Mate 10 Battery Disconnect, Disconnect the battery: adım 3, 2 resimden 1. Huawei Mate 10 Battery Disconnect, Disconnect the battery: adım 3, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
  4. Huawei Mate 10 Battery Disconnect, Disconnect the interconnect cable: adım 4, 2 resimden 1. Huawei Mate 10 Battery Disconnect, Disconnect the interconnect cable: adım 4, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the wide interconnect flex cable from its motherboard socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  5. Huawei Mate 10 Battery Disconnect: adım 5, 2 resimden 1. Huawei Mate 10 Battery Disconnect: adım 5, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the fingerprint extension cable from its motherboard socket.
Sonuç
Arthur Shi
283.744 İtibar
587 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
120 Üyeler
19.664 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 68
