Ana içeriğe geç
Huawei Mate 10 Pro Motherboard Replacement
Neye ihtiyacın var
  1. Huawei Mate 10 Pro Motherboard Replacement, SIM Card Tray: adım 1, 2 resimden 1. Huawei Mate 10 Pro Motherboard Replacement, SIM Card Tray: adım 1, 2 resimden 2.
    • Insert a SIM opening tool in the hole on the left side and push it in.
    • Remove the SIM card tray.
  2. Huawei Mate 10 Pro Motherboard Replacement, Back Cover: adım 2, 1 resimden 1.
    • Switch off your phone.
    • Prepare an iOpener and apply it to the back of the phone for about two minutes to loosen the adhesive beneath the back cover.
  3. Huawei Mate 10 Pro Motherboard Replacement: adım 3, 3 resimden 1. Huawei Mate 10 Pro Motherboard Replacement: adım 3, 3 resimden 2. Huawei Mate 10 Pro Motherboard Replacement: adım 3, 3 resimden 3.
    • Lift up the back cover with a suction cup until you can insert the flat end of a halberd spudger.
    • Use the halberd spudger to cut the adhesive beneath the back cover on all sides of the phone.
    • Use opening picks to avoid the adhesive from sticking to the back cover again while cutting the adhesive on all sides.
  4. Huawei Mate 10 Pro Motherboard Replacement: adım 4, 2 resimden 1. Huawei Mate 10 Pro Motherboard Replacement: adım 4, 2 resimden 2.
    • Don't remove the back cover all the way, yet. The fingerprint sensor cable is still connected to motherboard.
    • Flip the back cover over to the side.
    • Remove the Phillips #00 screw which holds down the metal shield, sitting on top of the connection of the fingerprint sensor cable.
  5. Huawei Mate 10 Pro Motherboard Replacement: adım 5, 2 resimden 1. Huawei Mate 10 Pro Motherboard Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use a pair tweezers to remove the metal shield covering the connector of the fingerprint sensor.
    • Disconnect the fingerprint sensor cable with a spudger.
    • When reassembling your phone apply new adhesive where it is necessary.
  6. Huawei Mate 10 Pro Motherboard Replacement, Motherboard: adım 6, 2 resimden 1. Huawei Mate 10 Pro Motherboard Replacement, Motherboard: adım 6, 2 resimden 2.
    Satın Al
    • Unscrew screws on black cover and remove using tweezers to leverage.
  7. Huawei Mate 10 Pro Motherboard Replacement: adım 7, 2 resimden 1. Huawei Mate 10 Pro Motherboard Replacement: adım 7, 2 resimden 2.
    • Pop off gold covers.
  8. Huawei Mate 10 Pro Motherboard Replacement: adım 8, 3 resimden 1. Huawei Mate 10 Pro Motherboard Replacement: adım 8, 3 resimden 2. Huawei Mate 10 Pro Motherboard Replacement: adım 8, 3 resimden 3.
    • Disconnect wires attached to motherboard assembly.
  9. Huawei Mate 10 Pro Motherboard Replacement: adım 9, 2 resimden 1. Huawei Mate 10 Pro Motherboard Replacement: adım 9, 2 resimden 2.
    • Wedge tweezers under motherboard and leverage assembly to pop assembly out.
  10. Huawei Mate 10 Pro Motherboard Replacement: adım 10, 1 resimden 1.
    • Separate camera assembly by popping it out, if only the motherboard is needed.
Sonuç
Annabelle Harding
433 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-5, Harley Spring 2022 IUPUI, Team 3-5, Harley Spring 2022 üyesi
IUPUI-HARLEY-S22S3G5
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 6
Son 30 gün: 36
Her zaman: 840
