Giriş
Use this guide to replace the defective display of your Huawei Mate 8.
Neye ihtiyacın var
Remove the liquid indicator sticker.
Remove the Phillips #00 screw that holds down the metal shield.
Use a spudger to remove the metal shield.
Get a good grip on the pull tab near the power button and peel out the adhesive strip by steadily pulling at the tab in a flat angle.
Heat an iOpener and place it on the phone for about a minute to loosen the remaining adhesive.
Carefully insert the flat end of a spudger to separate any remaining adhesive at the top of the battery.
Remove the four Phillips #00 screws holding the daughterboard and loudspeaker to the phone.
9 farklı kişi bu kılavuzu tamamladı.
