Ana içeriğe geç
Huawei Mate 8 Loudspeaker Replacement
Neye ihtiyacın var
  1. Huawei Mate 8 Loudspeaker Replacement, Back Cover: adım 1, 2 resimden 1. Huawei Mate 8 Loudspeaker Replacement, Back Cover: adım 1, 2 resimden 2.
    • Switch off your phone and remove the SIM card tray.
  2. Huawei Mate 8 Loudspeaker Replacement: adım 2, 1 resimden 1.
    • Remove the Torx T2 screws from the bottom of the phone
  3. Huawei Mate 8 Loudspeaker Replacement: adım 3, 2 resimden 1. Huawei Mate 8 Loudspeaker Replacement: adım 3, 2 resimden 2.
    • Use an iSclack or a suction handle in the bottom area of your phone to separate the display unit from the rear panel.
  4. Huawei Mate 8 Loudspeaker Replacement: adım 4, 3 resimden 1. Huawei Mate 8 Loudspeaker Replacement: adım 4, 3 resimden 2. Huawei Mate 8 Loudspeaker Replacement: adım 4, 3 resimden 3.
    • Use an opening pick to fully separate the clips, releasing the phone.
    • Do not fully remove the rear case. The fingerprint sensor cable is still connected to the back cover.
    • Open the phone like a book from the SIM tray side.
    • Use a spudger, to disconnect the fingerprint sensor cable.
  5. Huawei Mate 8 Loudspeaker Replacement, Daughterboard interconnect cable: adım 5, 3 resimden 1. Huawei Mate 8 Loudspeaker Replacement, Daughterboard interconnect cable: adım 5, 3 resimden 2. Huawei Mate 8 Loudspeaker Replacement, Daughterboard interconnect cable: adım 5, 3 resimden 3.
    • Remove the liquid indicator sticker.
    • Remove the Phillips #00 screw that holds down the metal shield.
    • The metal shield is tightly held in place. If you try to remove it without holding it down on one side, it'll break easily.
    • Use a spudger to remove the metal shield.
  6. Huawei Mate 8 Loudspeaker Replacement: adım 6, 3 resimden 1. Huawei Mate 8 Loudspeaker Replacement: adım 6, 3 resimden 2. Huawei Mate 8 Loudspeaker Replacement: adım 6, 3 resimden 3.
    • Use the flat end of a spudger to disconnect the display, daughterboard interconnect, and battery cables.
  7. Huawei Mate 8 Loudspeaker Replacement: adım 7, 1 resimden 1.
    • Remove the Phillips #00 screw that holds down the interconnect cable bracket.
  8. Huawei Mate 8 Loudspeaker Replacement: adım 8, 2 resimden 1. Huawei Mate 8 Loudspeaker Replacement: adım 8, 2 resimden 2.
    • Lift the coaxial connector off of its socket to allow access to the daughterboard interconnect cable bracket.
    • Remove the bracket.
  9. Huawei Mate 8 Loudspeaker Replacement: adım 9, 1 resimden 1.
    • Use a spudger to disconnect the interconnect cable.
    • Remove the interconnect cable.
  10. Huawei Mate 8 Loudspeaker Replacement, Charging Board: adım 10, 3 resimden 1. Huawei Mate 8 Loudspeaker Replacement, Charging Board: adım 10, 3 resimden 2. Huawei Mate 8 Loudspeaker Replacement, Charging Board: adım 10, 3 resimden 3.
    • Remove the two Phillips #00 screws.
    • Use the flat end a spudger to disconnect the loudspeaker flex connector.
    • Use the pointy end of a spudger to pry out the daughterboard.
    • Remove the daughterboard.
  11. Huawei Mate 8 Loudspeaker Replacement, Loudspeaker: adım 11, 3 resimden 1. Huawei Mate 8 Loudspeaker Replacement, Loudspeaker: adım 11, 3 resimden 2. Huawei Mate 8 Loudspeaker Replacement, Loudspeaker: adım 11, 3 resimden 3.
    • Use the tip of a spudger on the left side of the loudspeaker to pry it out.
    • Remove the loudspeaker.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Theo Mat
12.938 İtibar
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 23
Her zaman: 1,078
