Ana içeriğe geç
Huawei MateBook D 15 (2020) LCD Replacement
Neye ihtiyacın var
    1. Huawei MateBook D 15 (2020) LCD Replacement, Case removal: adım 1, 3 resimden 1. Huawei MateBook D 15 (2020) LCD Replacement, Case removal: adım 1, 3 resimden 2. Huawei MateBook D 15 (2020) LCD Replacement, Case removal: adım 1, 3 resimden 3.
      • Remove the 10 P5 screws securing the case.
      • Use a spudger to pry the edges of the case up, releasing the plastic tabs holding the base in place.
      FixBot'a Sor
      Yorum Ekle
    2. Huawei MateBook D 15 (2020) LCD Replacement, Battery removal: adım 2, 2 resimden 1. Huawei MateBook D 15 (2020) LCD Replacement, Battery removal: adım 2, 2 resimden 2.
      • Remove the 3 PH00 screws holding the battery in place.
      • Slide the battery forwards and lift it from its housing.
      • Do NOT remove the battery yet, as it is still connected to the motherboard.
      • Pry the end of the battery connector from its housing.
      • Remove the battery.
      • When reassembling, remember that replacing the battery cable in its housing requires a sliding motion in the direction of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Huawei MateBook D 15 (2020) LCD Replacement, Remove bezel: adım 3, 2 resimden 1. Huawei MateBook D 15 (2020) LCD Replacement, Remove bezel: adım 3, 2 resimden 2.
      • Using a spudger or pry tool, separate the screen bezel from the case.
      • The bezel is made from thin plastic that should not have too much force exerted on it. Exercise caution during this step.
      • Separate the bezel from the hinge housing and remove it.
      FixBot'a Sor
      Yorum Ekle
    4. Huawei MateBook D 15 (2020) LCD Replacement, Break LCD adhesive: adım 4, 2 resimden 1. Huawei MateBook D 15 (2020) LCD Replacement, Break LCD adhesive: adım 4, 2 resimden 2.
      • Insert a pry tool onto either side of the LCD and slide downwards towards the keyboard.
      • Repeat for the opposite side once all adhesive is broken. There are no delicate cables between this LCD and the top of the laptop case.
      • Fold the LCD upwards towards the keyboard.
      FixBot'a Sor
      Yorum Ekle
    5. Huawei MateBook D 15 (2020) LCD Replacement, Remove the LCD: adım 5, 2 resimden 1. Huawei MateBook D 15 (2020) LCD Replacement, Remove the LCD: adım 5, 2 resimden 2.
      • Remove the piece of tape holding the LCD cable in place
      • The LCD cable has two delicate outcroppings on each side which should not be used to pull the cable backwards.
      • Pull the cable away, removing it from the LCD.
      • Remove the LCD.
      • Follow these steps in reverse order to reassemble.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Pig PlayzMC
284 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 23
Son 7 gün: 103
Son 30 gün: 505
Her zaman: 6,728
