Ana içeriğe geç
Huawei MediaPad M3 Battery Replacement
Neye ihtiyacın var
  1. Huawei MediaPad M3 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Using the Jimmy tool, gently pry the display open.
    • Wear ESD bracelet to ensure you are electrostatic safe.
  2. Huawei MediaPad M3 Battery Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the six 3.0mm screws.
  3. Huawei MediaPad M3 Battery Replacement: adım 3, 1 resimden 1.
    • Using the tweezer tool, remove the ribbon cable attached to the main display in two places.
  4. Huawei MediaPad M3 Battery Replacement: adım 4, 3 resimden 1. Huawei MediaPad M3 Battery Replacement: adım 4, 3 resimden 2. Huawei MediaPad M3 Battery Replacement: adım 4, 3 resimden 3.
    • Using the tweezer tool, remove the three remaining ribbon cables.
  5. Huawei MediaPad M3 Battery Replacement: adım 5, 1 resimden 1.
    • Using the Jimmy, break the adhesive that holds the battery to the main body and remove the battery from the device.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 162
Her zaman: 7,080
