Ana içeriğe geç
Huawei MediaPad M3 Buttons Replacement
Neye ihtiyacın var
  1. Huawei MediaPad M3 Buttons Replacement, Buttons: adım 1, 1 resimden 1.
    • Using a Jimmy or opening tool, detach the screen from the main body of the device.
  2. Huawei MediaPad M3 Buttons Replacement: adım 2, 2 resimden 1. Huawei MediaPad M3 Buttons Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using a Phillips #00 screwdriver, remove the two screws.
    • Using tweezers, detach the ribbon cables from the device.
  3. Huawei MediaPad M3 Buttons Replacement: adım 3, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the two screws on the grey plastic part that holds the buttons in place.
    • Using a pair of tweezers, remove the grey plastic part gently.
  4. Huawei MediaPad M3 Buttons Replacement: adım 4, 2 resimden 1. Huawei MediaPad M3 Buttons Replacement: adım 4, 2 resimden 2.
    • Using tweezers, remove the rubber strip attached to the buttons.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 851
