Ana içeriğe geç
Huawei MediaPad M3 Display Assembly Replacement
Neye ihtiyacın var
  1. Huawei MediaPad M3 Display Assembly Replacement, Display Assembly: adım 1, 2 resimden 1. Huawei MediaPad M3 Display Assembly Replacement, Display Assembly: adım 1, 2 resimden 2.
    • Use a heat gun to heat the display. It may take up to 30 seconds.
    • Slide in the opening picks to the four corners of the tablet and peel off the display carefully.
    FixBot'a Sor
    Yorum Ekle
  2. Huawei MediaPad M3 Display Assembly Replacement: adım 2, 2 resimden 1. Huawei MediaPad M3 Display Assembly Replacement: adım 2, 2 resimden 2.
    • Open the display carefully.
    • Use a Phillips #00 screwdriver to remove the two 3.0mm screws.
    FixBot'a Sor
    Yorum Ekle
  3. Huawei MediaPad M3 Display Assembly Replacement: adım 3, 2 resimden 1. Huawei MediaPad M3 Display Assembly Replacement: adım 3, 2 resimden 2.
    • After removing the two screws, use your hand to take out the silver metal bracket.
    FixBot'a Sor
    Yorum Ekle
  4. Huawei MediaPad M3 Display Assembly Replacement: adım 4, 3 resimden 1. Huawei MediaPad M3 Display Assembly Replacement: adım 4, 3 resimden 2. Huawei MediaPad M3 Display Assembly Replacement: adım 4, 3 resimden 3.
    • Use the plastic opening tool to disconnect the two ribbon cable connectors.
    FixBot'a Sor
    Yorum Ekle
  5. Huawei MediaPad M3 Display Assembly Replacement: adım 5, 2 resimden 1. Huawei MediaPad M3 Display Assembly Replacement: adım 5, 2 resimden 2.
    • Remove the display assembly from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 52
Her zaman: 3,133
