Giriş
This guide is about how to replace the motherboard of Huawei MediaPad M3. A prerequisite of this guide is removing the display. The motherboard requires the removal of multiple screws; please store screws carefully for reassembly.
Neye ihtiyacın var
Use a heat gun to heat the display. It may take up to 30 seconds.
Slide in the opening picks to the four corners of the tablet and peel off the display carefully.
Use a Phillips #00 screwdriver to remove this 3mm screw.
Remove the small silver metal bracket.
3 farklı kişi bu kılavuzu tamamladı.
