Ana içeriğe geç
Huawei MediaPad S7-301u Battery Replacement
Neye ihtiyacın var
  1. Huawei MediaPad S7-301u Battery Replacement, Battery: adım 1, 3 resimden 1. Huawei MediaPad S7-301u Battery Replacement, Battery: adım 1, 3 resimden 2. Huawei MediaPad S7-301u Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Use either your finger or a metal spudger to lift both the top and bottom black covers on the back of the tablet.
  2. Huawei MediaPad S7-301u Battery Replacement: adım 2, 1 resimden 1.
    • Use a Phillips (J000) bit screwdriver to remove the 6 (2 mm) screws located at the top and bottom of the tablet.
  3. Huawei MediaPad S7-301u Battery Replacement: adım 3, 3 resimden 1. Huawei MediaPad S7-301u Battery Replacement: adım 3, 3 resimden 2. Huawei MediaPad S7-301u Battery Replacement: adım 3, 3 resimden 3.
    • Hold the device by the silver edge and the front of the screen.
    • Then use your other hand to push gently on the center back of the tablet until the front screen is detached from the silver back cover.
    • Finally, separate the screen from the silver back casing.
  4. Huawei MediaPad S7-301u Battery Replacement: adım 4, 3 resimden 1. Huawei MediaPad S7-301u Battery Replacement: adım 4, 3 resimden 2. Huawei MediaPad S7-301u Battery Replacement: adım 4, 3 resimden 3.
    • Use the plastic spudger to remove the battery from the device that is glued on the metal frame.
    • Be careful not to puncture the battery while removing it.
    • Follow the wires to where they are connected on the motherboard and simply pull the white connector out of the socket.
    • When removing the battery, be careful with the connector that attaches the wires to the motherboard.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Miguel Lugo
598 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S11-G5, Passmore Fall 2017 USF Tampa, Team S11-G5, Passmore Fall 2017 üyesi
USFT-PASSMORE-F17S11G5
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Thanks Miguel. Worked worked perfectly. My generationally challenged but still handy Mediapad is returned to service.
cheers,
Marcus
marcusinho_ab - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 7,016
