Ana içeriğe geç
Huawei MediaPad S7-301u Screen Replacement
Neye ihtiyacın var
  1. Huawei MediaPad S7-301u Screen Replacement, Battery: adım 1, 3 resimden 1. Huawei MediaPad S7-301u Screen Replacement, Battery: adım 1, 3 resimden 2. Huawei MediaPad S7-301u Screen Replacement, Battery: adım 1, 3 resimden 3.
    • Use either your finger or a metal spudger to lift both the top and bottom black covers on the back of the tablet.
  2. Huawei MediaPad S7-301u Screen Replacement: adım 2, 1 resimden 1.
    • Use a Phillips (J000) bit screwdriver to remove the 6 (2 mm) screws located at the top and bottom of the tablet.
  3. Huawei MediaPad S7-301u Screen Replacement: adım 3, 3 resimden 1. Huawei MediaPad S7-301u Screen Replacement: adım 3, 3 resimden 2. Huawei MediaPad S7-301u Screen Replacement: adım 3, 3 resimden 3.
    • Hold the device by the silver edge and the front of the screen.
    • Then use your other hand to push gently on the center back of the tablet until the front screen is detached from the silver back cover.
    • Finally, separate the screen from the silver back casing.
  4. Huawei MediaPad S7-301u Screen Replacement: adım 4, 3 resimden 1. Huawei MediaPad S7-301u Screen Replacement: adım 4, 3 resimden 2. Huawei MediaPad S7-301u Screen Replacement: adım 4, 3 resimden 3.
    • Use the plastic spudger to remove the battery from the device that is glued on the metal frame.
    • Be careful not to puncture the battery while removing it.
    • Follow the wires to where they are connected on the motherboard and simply pull the white connector out of the socket.
    • When removing the battery, be careful with the connector that attaches the wires to the motherboard.
  5. Huawei MediaPad S7-301u Screen Replacement, Motherboard: adım 5, 3 resimden 1. Huawei MediaPad S7-301u Screen Replacement, Motherboard: adım 5, 3 resimden 2. Huawei MediaPad S7-301u Screen Replacement, Motherboard: adım 5, 3 resimden 3.
    • Once the battery is removed, the motherboard is ready to be removed.
    • Remove the camera from the motherboard by disconnecting the clip next to it. You can use the precision tweezer here.
    • To remove the power port from the motherboard, unscrew the two 4mm screws with a T5 bit.
  6. Huawei MediaPad S7-301u Screen Replacement: adım 6, 3 resimden 1. Huawei MediaPad S7-301u Screen Replacement: adım 6, 3 resimden 2. Huawei MediaPad S7-301u Screen Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the precision tweezers to disconnect the 7 clips from the motherboard
    • Remove the headphone input cable from the motherboard by carefully pulling on the clip.
  7. Huawei MediaPad S7-301u Screen Replacement: adım 7, 2 resimden 1. Huawei MediaPad S7-301u Screen Replacement: adım 7, 2 resimden 2.
    • Unscrew the 4 screws 4mm with T5 bit from the edges or the frame of the motherboard to remove it
    • Carefully remove the motherboard from the metal frame.
    • A long thin tape will be attached to the motherboard. This tape can be pulled along with the motherboard.
  8. Huawei MediaPad S7-301u Screen Replacement, Screen: adım 8, 1 resimden 1.
    • Remove the 7 2mm screws for on the metal frame. Use a J000 screwdriver.
  9. Huawei MediaPad S7-301u Screen Replacement: adım 9, 2 resimden 1. Huawei MediaPad S7-301u Screen Replacement: adım 9, 2 resimden 2.
    • Carefully remove the LCD from the front glass casing.
    • While separating the LCD from the device, be careful not to introduce any debris.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Miguel Lugo
598 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S11-G5, Passmore Fall 2017 USF Tampa, Team S11-G5, Passmore Fall 2017 üyesi
USFT-PASSMORE-F17S11G5
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 2,520
