Ana içeriğe geç
Huawei P10 Back Cover Replacement
Neye ihtiyacın var
  1. Huawei P10 Back Cover Replacement, Back Cover: adım 1, 3 resimden 1. Huawei P10 Back Cover Replacement, Back Cover: adım 1, 3 resimden 2. Huawei P10 Back Cover Replacement, Back Cover: adım 1, 3 resimden 3.
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Huawei P10 Back Cover Replacement: adım 2, 3 resimden 1. Huawei P10 Back Cover Replacement: adım 2, 3 resimden 2. Huawei P10 Back Cover Replacement: adım 2, 3 resimden 3.
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Huawei P10 Back Cover Replacement: adım 3, 2 resimden 1. Huawei P10 Back Cover Replacement: adım 3, 2 resimden 2.
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
211.944 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
140 Üyeler
18.139 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 60
Her zaman: 7,954
