Ana içeriğe geç
Huawei P10 Display Replacement
Neye ihtiyacın var
  1. Huawei P10 Display Replacement, Back Cover: adım 1, 3 resimden 1. Huawei P10 Display Replacement, Back Cover: adım 1, 3 resimden 2. Huawei P10 Display Replacement, Back Cover: adım 1, 3 resimden 3.
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Huawei P10 Display Replacement: adım 2, 3 resimden 1. Huawei P10 Display Replacement: adım 2, 3 resimden 2. Huawei P10 Display Replacement: adım 2, 3 resimden 3.
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Huawei P10 Display Replacement: adım 3, 2 resimden 1. Huawei P10 Display Replacement: adım 3, 2 resimden 2.
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
  4. Huawei P10 Display Replacement, Main and display flex disconnect: adım 4, 3 resimden 1. Huawei P10 Display Replacement, Main and display flex disconnect: adım 4, 3 resimden 2. Huawei P10 Display Replacement, Main and display flex disconnect: adım 4, 3 resimden 3.
    • Remove the two Phillips #00 screws.
    • Use tweezers to remove both metal plates.
  5. Huawei P10 Display Replacement: adım 5, 3 resimden 1. Huawei P10 Display Replacement: adım 5, 3 resimden 2. Huawei P10 Display Replacement: adım 5, 3 resimden 3.
    • Use a spudger to disconnect the interconnect, the battery and the display flex cable.
  6. Huawei P10 Display Replacement, Charging Board: adım 6, 2 resimden 1. Huawei P10 Display Replacement, Charging Board: adım 6, 2 resimden 2.
    • Remove the four Phillips #00 screws.
    • Use Tweezers to remove the metal plate.
  7. Huawei P10 Display Replacement: adım 7, 2 resimden 1. Huawei P10 Display Replacement: adım 7, 2 resimden 2.
    • Use a spudger to disconnect the main flex cable.
    • Use tweezers to disconnect the antenna cable and pull it out of the clamp holding it down to the charging board.
  8. Huawei P10 Display Replacement: adım 8, 2 resimden 1. Huawei P10 Display Replacement: adım 8, 2 resimden 2.
    • Use a spudger to disconnect the headphone jack and the loudspeaker flex cables.
  9. Huawei P10 Display Replacement: adım 9, 2 resimden 1. Huawei P10 Display Replacement: adım 9, 2 resimden 2.
    • Do not damage any components sitting on the charging board while removing it.
    • Use a spudger to pry out the charging board.
    • Remove the charging board.
  10. Huawei P10 Display Replacement, Loudspeaker: adım 10, 2 resimden 1. Huawei P10 Display Replacement, Loudspeaker: adım 10, 2 resimden 2.
    • Only insert the spudger as deep as 1/16 of an inch to avoid damage.
    • Use a spudger to carefully pry out the loudspeaker. There is some adhesive underneath so it might be a little bit sticky. You can use an iOpener to loosen it.
    • Remove the loudspeaker.
    • When reassembling your phone, apply new adhesive where it's necessary.
  11. Huawei P10 Display Replacement, Display: adım 11, 2 resimden 1. Huawei P10 Display Replacement, Display: adım 11, 2 resimden 2.
    • Remove the antenna cable if you haven't already.
    • Use tweezers to remove the interconnect cable.
    • Use an iOpener to loosen the adhesive beneath the display. Especially take care of the upper and lower part of the display.
  12. Huawei P10 Display Replacement: adım 12, 3 resimden 1. Huawei P10 Display Replacement: adım 12, 3 resimden 2. Huawei P10 Display Replacement: adım 12, 3 resimden 3.
    • Insert the tip of an opening pick between the display and the midframe on the bottom of the phone, near the home button.
    • Slide the opening pick along the bottom edge, to cut the adhesive.
    • Slide the opening pick to the bottom right corner and leave it there.
    • Insert another opening pick under the screen on the bottom left corner.
  13. Huawei P10 Display Replacement: adım 13, 3 resimden 1. Huawei P10 Display Replacement: adım 13, 3 resimden 2. Huawei P10 Display Replacement: adım 13, 3 resimden 3.
    • Slide the opening pick under the screen around all edges of the phone.
    • If the adhesive gets tough to pry it is likely too cold. Use your iOpener or heat gun to reheat it.
  14. Huawei P10 Display Replacement: adım 14, 2 resimden 1. Huawei P10 Display Replacement: adım 14, 2 resimden 2.
    • Carefully pull the display assembly away from the frame.
    • Remove the display assembly.
Sonuç
23 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
202.516 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.718 adet Kılavuz yazıldı
4 Yorum
Any advice which adhesive to use? I’ve seen a russian replacement video, it looked like the guy was using some kind of silicone.
Tom My - Yanıt
I used B-7000 glue. It enables you to release the screen when a second replacement is needed.
teunkeusters -
Assuming I purchase a screen off of ebay, and replace it using this method, will the touch id still work?
Simon Fisher - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 61
Her zaman: 26,566
