Ana içeriğe geç
Huawei P10 Lite Back cover Replacement
Neye ihtiyacın var
  1. Huawei P10 Lite Back cover Replacement, Back cover: adım 1, 3 resimden 1. Huawei P10 Lite Back cover Replacement, Back cover: adım 1, 3 resimden 2. Huawei P10 Lite Back cover Replacement, Back cover: adım 1, 3 resimden 3.
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
  2. Huawei P10 Lite Back cover Replacement: adım 2, 3 resimden 1. Huawei P10 Lite Back cover Replacement: adım 2, 3 resimden 2. Huawei P10 Lite Back cover Replacement: adım 2, 3 resimden 3.
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Huawei P10 Lite Back cover Replacement: adım 3, 2 resimden 1. Huawei P10 Lite Back cover Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
  4. Huawei P10 Lite Back cover Replacement: adım 4, 2 resimden 1. Huawei P10 Lite Back cover Replacement: adım 4, 2 resimden 2.
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
228.969 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.410 adet Kılavuz yazıldı
6 Yorum
Great guide, but how do I move the fingerprint sensor to the new cover?
mela ross - Yanıt
You need to warm the adhesive so it can be loose
Adwell Cellular -
What adhesive should I use? Thank you!
Calin GV - Yanıt
Nice guide! Thanks! I got a little question about the coloring of the back panel. What kind of coloring is it? Is it a coating you can take off, or is it more like a layer of paint you can scrape off? I am wondering, because I want to clear the back of my Huawei P10 lite. I hope it’s possible though.
Daan - Yanıt
Can you send me please back cover.
I'm from Nepal .
Md Usman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 60
Her zaman: 39,407
