Ana içeriğe geç
Huawei P10 Lite Charging Board Replacement
Neye ihtiyacın var
  1. Huawei P10 Lite Charging Board Replacement, Back cover: adım 1, 3 resimden 1. Huawei P10 Lite Charging Board Replacement, Back cover: adım 1, 3 resimden 2. Huawei P10 Lite Charging Board Replacement, Back cover: adım 1, 3 resimden 3.
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
  2. Huawei P10 Lite Charging Board Replacement: adım 2, 3 resimden 1. Huawei P10 Lite Charging Board Replacement: adım 2, 3 resimden 2. Huawei P10 Lite Charging Board Replacement: adım 2, 3 resimden 3.
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Huawei P10 Lite Charging Board Replacement: adım 3, 2 resimden 1. Huawei P10 Lite Charging Board Replacement: adım 3, 2 resimden 2.
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
  4. Huawei P10 Lite Charging Board Replacement: adım 4, 2 resimden 1. Huawei P10 Lite Charging Board Replacement: adım 4, 2 resimden 2.
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
  5. Huawei P10 Lite Charging Board Replacement, Battery Disconnection: adım 5, 3 resimden 1. Huawei P10 Lite Charging Board Replacement, Battery Disconnection: adım 5, 3 resimden 2. Huawei P10 Lite Charging Board Replacement, Battery Disconnection: adım 5, 3 resimden 3.
    • Remove the Phillips screw holding the battery connector plate in place.
    • Remove the battery connector plate.
    • Use the flat end of a spudger to disconnect the battery flex cable.
  6. Huawei P10 Lite Charging Board Replacement, Loudspeaker / Vibration Motor: adım 6, 1 resimden 1.
    • Remove the seven Philipps #000 screws.
  7. Huawei P10 Lite Charging Board Replacement: adım 7, 3 resimden 1. Huawei P10 Lite Charging Board Replacement: adım 7, 3 resimden 2. Huawei P10 Lite Charging Board Replacement: adım 7, 3 resimden 3.
    • Insert an opening pick under the right edge of the loudspeaker unit and lever it up.
    • Grab the loudspeaker unit and remove it.
  8. Huawei P10 Lite Charging Board Replacement: adım 8, 2 resimden 1. Huawei P10 Lite Charging Board Replacement: adım 8, 2 resimden 2.
    • Use an iOpener to loosen the glue under the vibration motor.
    • Remove the vibration motor.
  9. Huawei P10 Lite Charging Board Replacement, Charging Board: adım 9, 2 resimden 1. Huawei P10 Lite Charging Board Replacement, Charging Board: adım 9, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the interconnect cable.
    • Use tweezers to disconnect the antenna cable.
  10. Huawei P10 Lite Charging Board Replacement: adım 10, 2 resimden 1. Huawei P10 Lite Charging Board Replacement: adım 10, 2 resimden 2.
    • Use an iOpener to loosen the adhesive under the charging board.
    • Remove the charging board.
Sonuç
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
5 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
202.836 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.734 adet Kılavuz yazıldı
3 Yorum
thanks and very nice
mj41574 - Yanıt
thanks to all team
mj41574 - Yanıt
p10 lite charging ic change daigram
mj41574 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 56
Her zaman: 9,720
