Ana içeriğe geç
Huawei P10 Lite Headphone Jack Replacement
Neye ihtiyacın var
  1. Huawei P10 Lite Headphone Jack Replacement, Back cover: adım 1, 3 resimden 1. Huawei P10 Lite Headphone Jack Replacement, Back cover: adım 1, 3 resimden 2. Huawei P10 Lite Headphone Jack Replacement, Back cover: adım 1, 3 resimden 3.
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
  2. Huawei P10 Lite Headphone Jack Replacement: adım 2, 3 resimden 1. Huawei P10 Lite Headphone Jack Replacement: adım 2, 3 resimden 2. Huawei P10 Lite Headphone Jack Replacement: adım 2, 3 resimden 3.
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Huawei P10 Lite Headphone Jack Replacement: adım 3, 2 resimden 1. Huawei P10 Lite Headphone Jack Replacement: adım 3, 2 resimden 2.
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
  4. Huawei P10 Lite Headphone Jack Replacement: adım 4, 2 resimden 1. Huawei P10 Lite Headphone Jack Replacement: adım 4, 2 resimden 2.
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
  5. Huawei P10 Lite Headphone Jack Replacement, Battery Disconnection: adım 5, 3 resimden 1. Huawei P10 Lite Headphone Jack Replacement, Battery Disconnection: adım 5, 3 resimden 2. Huawei P10 Lite Headphone Jack Replacement, Battery Disconnection: adım 5, 3 resimden 3.
    • Remove the Phillips screw holding the battery connector plate in place.
    • Remove the battery connector plate.
    • Use the flat end of a spudger to disconnect the battery flex cable.
  6. Huawei P10 Lite Headphone Jack Replacement, Headphone Jack: adım 6, 2 resimden 1. Huawei P10 Lite Headphone Jack Replacement, Headphone Jack: adım 6, 2 resimden 2.
    • Use the flat end of a spuder to disconnect the headphone jack flex cable.
    • Altough the headphone jack is not glued to the mid frame it is a little bit tucked in its bracket. Be careful not to damage it during the removal.
    • Remove the headphone jack.
Sonuç
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
2 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
203.362 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.817 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 3,348
