Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
Use this guide to replace the loudspeaker and/or the vibration motor in your Huawei P10 Lite smartphone. When reassembling your phone apply new adhesive where it is necessary.
  1. Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive. Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in. If the adhesive is hard to cut, use an iOpener to loosen it.
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
  2. After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone. Flip the rear cover over to the right side of the phone. Flip the rear cover over to the right side of the phone.
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Use a pair of tweezers to remove the sticker. Remove the two Phillips #00 screws.
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
  4. Manta Tornavida Seti
    112 bits for every fix.
    Upgrade Your Toolbox
  5. Use tweezers to remove the mainboard shield. Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
  6. Remove the Phillips screw holding the battery connector plate in place. Remove the battery connector plate. Use the flat end of a spudger to disconnect the battery flex cable.
    • Remove the Phillips screw holding the battery connector plate in place.
    • Remove the battery connector plate.
    • Use the flat end of a spudger to disconnect the battery flex cable.
  7. Remove the seven Philipps #000 screws.
    • Remove the seven Philipps #000 screws.
  8. Insert an opening pick under the right edge of the loudspeaker unit and lever it up. Grab the loudspeaker unit and remove it. Grab the loudspeaker unit and remove it.
    • Insert an opening pick under the right edge of the loudspeaker unit and lever it up.
    • Grab the loudspeaker unit and remove it.
  9. Use an iOpener to loosen the glue under the vibration motor. Remove the vibration motor.
    • Use an iOpener to loosen the glue under the vibration motor.
    • Remove the vibration motor.
Sonuç
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Dominik Schnabelrauch
59.936 İtibar
279 adet Kılavuz yazıldı
Takım
iFixit iFixit üyesi
Community
115 Üyeler
11.168 adet Kılavuz yazıldı
Bir Yorum
is it necessary to disconnect the finger print sensor flex cable in order to remove/replace the loudspeaker, or is just a precaution!?
Ricardo Mendes - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 19
Son 30 gün: 102
Her zaman: 2,237
