Ana içeriğe geç
Huawei P10 Lite Loudspeaker / Vibration Motor Replacement
Neye ihtiyacın var
  1. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Back cover: adım 1, 3 resimden 1. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Back cover: adım 1, 3 resimden 2. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Back cover: adım 1, 3 resimden 3.
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
    Mit dem Saugnapf die Rückseite anheben hilft ungemein…
    Matthias Eberle - Yanıt
    Had to use blue wedge tool to wedge open bottom plate from the rim part in order to then use the tip of the blue opening pick under the back plate to then cut the glue. It’s like placing a pie server or knife under the plate once there’s a gap between the rim and the back plate.
    Jane - Yanıt
    Be careful, there’s a cable to fingerprint sensor, very close to the edge (see pictures below)… It’s very easy to cut it through with the pick, as I just learned :)
    dambig - Yanıt
  2. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: adım 2, 3 resimden 1. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: adım 2, 3 resimden 2. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: adım 2, 3 resimden 3.
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: adım 3, 2 resimden 1. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: adım 3, 2 resimden 2.
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
    Schritt 3 und 4 kann man sich komplett sparen. Wozu auch. Kann gleich mit Schritt 5 weitergemacht werden, zuvor einfach das Flachbandkabel vom Fingerabdrucksensor an der Rückabdeckung abklemmen und fertig.
    Bobby mcgee - Yanıt
    There are four silver screws and two black to be removed.
    Jane - Yanıt
    Translate what Bobby mcgee said:
    Step 3 and 4 can be completely ignored. What for? You can continue with step 5, just disconnect the ribbon cable from the fingerprint sensor on the back cover and you're done.
    Antonio Sun - Yanıt
    However, the reason step 3 and 4 should not be skipped is Step 6 — Use an iOpener to loosen the adhesive beneath the battery. I.e., the adhesive cannot be easily removed without heat, however, that heat might damage the electric chips. Thus they’d better be removed first.
    Antonio Sun - Yanıt
  4. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: adım 4, 2 resimden 1. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: adım 4, 2 resimden 2.
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
    Welchen Klebstoff soll man verwenden?
    josef navratil - Yanıt
    Hallo Josef,
    sollte bei deinem Ersatzteil kein Klebstoff oder Klebeband dabei gewesen sein, kannst du dünne Streifen Doppelseitiges Klebeband verwenden. Es gibt für das Huawei P10 Lite auch schon zugeschnittene Klebestreifen zu erwerben, hierbei gilt aber je nach Händler Rezessionen zu lesen, ob die Klebestreifen auch wirklich halten.
    Dominik Schnabelrauch -
    Note that there is a copper-colored sticker to lift up near the flat cable connected from the phone the finger pad. Lift the main board plate (shield) up SLOWLY from the camera side to the other end as the plate is wedged in place.
    Jane - Yanıt
    what adhesive is recommended? thanks
    darren - Yanıt
    Hi darren,
    pre-cut adhesive would be the best solution if you can source it. Otherwise a two-sided adhesive tape or carefully used E6000 adhesive glue will be your friend.
    Tobias Isakeit -
  5. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Battery Disconnection: adım 5, 3 resimden 1. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Battery Disconnection: adım 5, 3 resimden 2. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Battery Disconnection: adım 5, 3 resimden 3.
    • Remove the Phillips screw holding the battery connector plate in place.
    • Remove the battery connector plate.
    • Use the flat end of a spudger to disconnect the battery flex cable.
    Very gently lift the silver connecter that was under the battery connecter plate and is at the end of the orange battery cable with the flat end of the spudger as indicated.
    Jane - Yanıt
  6. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement, Loudspeaker / Vibration Motor: adım 6, 1 resimden 1.
    • Remove the seven Philipps #000 screws.
  7. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: adım 7, 3 resimden 1. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: adım 7, 3 resimden 2. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: adım 7, 3 resimden 3.
    • Insert an opening pick under the right edge of the loudspeaker unit and lever it up.
    • Grab the loudspeaker unit and remove it.
  8. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: adım 8, 2 resimden 1. Huawei P10 Lite Loudspeaker / Vibration Motor Replacement: adım 8, 2 resimden 2.
    • Use an iOpener to loosen the glue under the vibration motor.
    • Remove the vibration motor.
Sonuç
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
2 farklı kişi bu kılavuzu tamamladı.
203.160 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.767 adet Kılavuz yazıldı
Bir Yorum
is it necessary to disconnect the finger print sensor flex cable in order to remove/replace the loudspeaker, or is just a precaution!?
Ricardo Mendes - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 4,222
