Ana içeriğe geç
Huawei P20 Pro Rear Camera Lens Replacement
  1. Huawei P20 Pro Rear Camera Lens Replacement, Rear Camera Lens: adım 1, 1 resimden 1.
    • Start by placing your phone screen down on a clean, well-lit surface.
    • Wear safety glasses/goggles to protect your eyes from glass shards. This is very important.
  2. Huawei P20 Pro Rear Camera Lens Replacement: adım 2, 2 resimden 1. Huawei P20 Pro Rear Camera Lens Replacement: adım 2, 2 resimden 2.
    • Start removing the tiny shards of glass with straight precision tweezers. Place the shards of glass in a container for safe disposal.
    • A heat gun or a hair dryer may be helpful for loosening the adhesive on the glass.
  3. Huawei P20 Pro Rear Camera Lens Replacement: adım 3, 1 resimden 1.
    • Once the area is well cleaned, apply 2 dots of glue (B7000) on each end on the back of the new lens.
    • If not available, place double-sided adhesive strips in the gaps between the cameras.
    • Reposition the replacement lens in the broken lens’ original location, being careful not to leave any marks or debris on the inside of the camera area.
  4. Huawei P20 Pro Rear Camera Lens Replacement: adım 4, 1 resimden 1.
    • All done! You can take pictures again like you were able to do before.
Sonuç
After replacing the camera lens, clean it with a microfiber cloth to remove dust and/or fingerprints.
17 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
fr en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
cPix
3.971 İtibar
8 adet Kılavuz yazıldı
2 Yorum
Tuto très bien expliquer je vais pouvoir maintenant reprendre de belles photos grâce à vous. Merci
Ace Ace - Yanıt
Für das Erwärmen beim Lösen oder Anbringen des neuen Kameraglases mit Klebestreifen empfiehlt sich eine Wärmflasche. Klebereste lassen sich effektiv mit Alkohol, zum Beispiel Isopropanol, entfernen. Um die Sicht zu verbessern, können günstige Lesebrillen (+3 dpt) aus dem Supermarkt für wenige Euros als Lupe genutzt werden.
256 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 46
Son 30 gün: 152
Her zaman: 58,014
