Ana içeriğe geç
Giriş
Use this guide to remove the motherboard cover and the NFC in the Huawei P20 Pro.
Opening the Huawei P20 Pro will damage the waterproof sealing on the device. If you do not replace the adhesive seals, your phone will function normally, but will lose its water-protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
  1. Switch off your phone.
    • Switch off your phone.
    • Use an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
    • The adhesive of the Huawei P20 Pro is of moderate strength, however a hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
  2. If the phone's rear glass is cracked, a suction cup may not stick very well. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed. Press a suction cup onto the rear glass close to the bottom edge of the phone. Lift the bottom edge with the suction cup, opening a slight gap between the rear glass and the frame.
    • If the phone's rear glass is cracked, a suction cup may not stick very well. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the rear glass close to the bottom edge of the phone.
    • Lift the bottom edge with the suction cup, opening a slight gap between the rear glass and the frame.
    • Insert an opening pick in the gap and slide it to the bottom right corner. Leave it there to prevent the adhesive from resealing.
  3. Insert a second opening pick and slide it to the bottom left corner. Leave it there to prevent the adhesive from resealing. Insert a second opening pick and slide it to the bottom left corner. Leave it there to prevent the adhesive from resealing.
    • Insert a second opening pick and slide it to the bottom left corner. Leave it there to prevent the adhesive from resealing.
  4. Insert a third opening pick at the bottom left corner. Slide the tip of the opening pick along the left edge of the phone to cut the adhesive. Leave the opening pick in the top left corner of the phone to prevent the adhesive from resealing.
    • Insert a third opening pick at the bottom left corner.
    • Slide the tip of the opening pick along the left edge of the phone to cut the adhesive.
    • Leave the opening pick in the top left corner of the phone to prevent the adhesive from resealing.
  5. In case you're having trouble to cut the adhesive, reapply the iOpener for another minute to loosen it. Insert a fourth opening pick at the top left corner of the phone.
    • In case you're having trouble to cut the adhesive, reapply the iOpener for another minute to loosen it.
    • Insert a fourth opening pick at the top left corner of the phone.
    • Slide the opening pick along the upper edge of the phone to cut the adhesive beneath the rear glass and leave it in the top right corner.
  6. Insert a fifth opening pick at the top right corner of the rear glass. Slide the opening pick along the right edge of the phone to cut the remaining adhesive. Don't open the phone all the way yet. The proximity sensor flex cable is still connected to the motherboard.
    • Insert a fifth opening pick at the top right corner of the rear glass.
    • Slide the opening pick along the right edge of the phone to cut the remaining adhesive.
    • Don't open the phone all the way yet. The proximity sensor flex cable is still connected to the motherboard.
  7. Carefully lift the rear glass until you can reach the connector of the proximity sensor flex cable next to the rear camera assembly. Carefully lift the rear glass until you can reach the connector of the proximity sensor flex cable next to the rear camera assembly. Carefully lift the rear glass until you can reach the connector of the proximity sensor flex cable next to the rear camera assembly.
    • Carefully lift the rear glass until you can reach the connector of the proximity sensor flex cable next to the rear camera assembly.
  8. Use the flat end of a spudger to pry up and disconnect the proximity sensor flex cable. Use the flat end of a spudger to pry up and disconnect the proximity sensor flex cable.
    • Use the flat end of a spudger to pry up and disconnect the proximity sensor flex cable.
  9. Remove the rear glass. Before installing fresh adhesive and reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • Remove the rear glass.
    • Before installing fresh adhesive and reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
  10. Remove the nine Phillips #00 screws (3.4 mm length).
    • Remove the nine Phillips #00 screws (3.4 mm length).
  11. Insert an opening pick under the left side of the motherboard cover that includes the NFC. Slide the opening pick towards the top left corner of the phone and twist it to pry the cover out of its plastic clamps. Slide the opening pick towards the top left corner of the phone and twist it to pry the cover out of its plastic clamps.
    • Insert an opening pick under the left side of the motherboard cover that includes the NFC.
    • Slide the opening pick towards the top left corner of the phone and twist it to pry the cover out of its plastic clamps.
  12. Repeat the previous process on the right side and twist the opening pick to pry up the motherboard cover. Repeat the previous process on the right side and twist the opening pick to pry up the motherboard cover.
    • Repeat the previous process on the right side and twist the opening pick to pry up the motherboard cover.
  13. Remove the motherboard cover.
    • Remove the motherboard cover.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
99.158 İtibar
400 adet Kılavuz yazıldı
Takım
iFixit iFixit üyesi
Community
142 Üyeler
17.070 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 70
Her zaman: 2,863
