Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Use this guide to remove the motherboard cover and the NFC in the Huawei P20 Pro.
Opening the Huawei P20 Pro will damage the waterproof sealing on the device. If you do not replace the adhesive seals, your phone will function normally, but will lose its water-protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
Neye ihtiyacın var
Switch off your phone.
Use an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
Press a suction cup onto the rear glass close to the bottom edge of the phone.
Lift the bottom edge with the suction cup, opening a slight gap between the rear glass and the frame.
Insert an opening pick in the gap and slide it to the bottom right corner. Leave it there to prevent the adhesive from resealing.
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
merci beaucoup pour votre travail. J'attire votre attention sur un point important : ne pas enlever le film en plastique noir de la partie métallique sans d’extrême précaution. . Il y a une petite partie conductive sur le coté gauche (sous le trou rond gris) qui se déchire facilement et qui n'est pas réparable sil elle est déchirée...
