Giriş
If the rear camera's glass lens is broken on your Huawei P20 Pro, then you should replace that lens. This repair is simple but requires patience and precision. For the repair you will first have to remove the small pieces of shattered glass, then clean the area and glue the new lens with double-sided tape or simply by making 2 points of glue. The goal is to avoid touching or damaging the camera and avoid scratching it.
Once the area is well cleaned, apply 2 dots of glue (B7000) on each end on the back of the new lens.
If not available, place double-sided adhesive strips in the gaps between the cameras.
Reposition the replacement lens in the broken lens’ original location, being careful not to leave any marks or debris on the inside of the camera area.
After replacing the camera lens, clean it with a microfiber cloth to remove dust and/or fingerprints.
20 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
2 Yorum
Für das Erwärmen beim Lösen oder Anbringen des neuen Kameraglases mit Klebestreifen empfiehlt sich eine Wärmflasche. Klebereste lassen sich effektiv mit Alkohol, zum Beispiel Isopropanol, entfernen. Um die Sicht zu verbessern, können günstige Lesebrillen (+3 dpt) aus dem Supermarkt für wenige Euros als Lupe genutzt werden.
