Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Use this guide to replace a cracked rear glass of the Huawei P20 Pro.
Opening the Huawei P20 Pro will damage the waterproof sealing on the device. If you do not replace the adhesive seals, your phone will function normally but will lose its water-protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
  1. Switch off your phone.
    • Switch off your phone.
    • Use an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
    • The adhesive of the Huawei P20 Pro is of moderate strength, however a hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
  2. If the phone's rear glass is cracked, a suction cup may not stick very well. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed. Press a suction cup onto the rear glass close to the bottom edge of the phone. Lift the bottom edge with the suction cup, opening a slight gap between the rear glass and the frame.
    • If the phone's rear glass is cracked, a suction cup may not stick very well. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the rear glass close to the bottom edge of the phone.
    • Lift the bottom edge with the suction cup, opening a slight gap between the rear glass and the frame.
    • Insert an opening pick in the gap and slide it to the bottom right corner. Leave it there to prevent the adhesive from resealing.
    if the back cover is not broken, i’d suggest NOT to use an opening pick as if the phone was not heated enough, you may crack the glass on the edges. better use the iPlastix, it is thinner and less stressful for the glass.
    Stefano Restuccia - Yanıt
    It is better to put a peak on the side because the side opens first than the bottom of the phone.
    이정일 - Yanıt
    I have to agree that is is much easier to start opening from the side. Do read the rest of the guide though, to make sure you won’t hit something when opening it from the side.
    Jacob Cain - Yanıt
  3. Insert a second opening pick and slide it to the bottom left corner. Leave it there to prevent the adhesive from resealing. Insert a second opening pick and slide it to the bottom left corner. Leave it there to prevent the adhesive from resealing.
    • Insert a second opening pick and slide it to the bottom left corner. Leave it there to prevent the adhesive from resealing.
  4. Insert a third opening pick at the bottom left corner. Slide the tip of the opening pick along the left edge of the phone to cut the adhesive. Leave the opening pick in the top left corner of the phone to prevent the adhesive from resealing.
    • Insert a third opening pick at the bottom left corner.
    • Slide the tip of the opening pick along the left edge of the phone to cut the adhesive.
    • Leave the opening pick in the top left corner of the phone to prevent the adhesive from resealing.
  5. In case you're having trouble to cut the adhesive, reapply the iOpener for another minute to loosen it. Insert a fourth opening pick at the top left corner of the phone.
    • In case you're having trouble to cut the adhesive, reapply the iOpener for another minute to loosen it.
    • Insert a fourth opening pick at the top left corner of the phone.
    • Slide the opening pick along the upper edge of the phone to cut the adhesive beneath the rear glass and leave it in the top right corner.
  6. Insert a fifth opening pick at the top right corner of the rear glass. Slide the opening pick along the right edge of the phone to cut the remaining adhesive. Don't open the phone all the way yet. The proximity sensor flex cable is still connected to the motherboard.
    • Insert a fifth opening pick at the top right corner of the rear glass.
    • Slide the opening pick along the right edge of the phone to cut the remaining adhesive.
    • Don't open the phone all the way yet. The proximity sensor flex cable is still connected to the motherboard.
  7. Carefully lift the rear glass until you can reach the connector of the proximity sensor flex cable next to the rear camera assembly. Carefully lift the rear glass until you can reach the connector of the proximity sensor flex cable next to the rear camera assembly. Carefully lift the rear glass until you can reach the connector of the proximity sensor flex cable next to the rear camera assembly.
    • Carefully lift the rear glass until you can reach the connector of the proximity sensor flex cable next to the rear camera assembly.
  8. Use the flat end of a spudger to pry up and disconnect the proximity sensor flex cable. Use the flat end of a spudger to pry up and disconnect the proximity sensor flex cable.
    • Use the flat end of a spudger to pry up and disconnect the proximity sensor flex cable.
  9. Remove the rear glass. Before installing fresh adhesive and reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • Remove the rear glass.
    • Before installing fresh adhesive and reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
Sonuç
After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
11 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
88.988 İtibar
375 adet Kılavuz yazıldı
Takım
iFixit iFixit üyesi
Community
134 Üyeler
15.653 adet Kılavuz yazıldı
5 Yorum
Do you suggest any particular kind of adhesive? I always have trouble with these things. Sooner or later, if not immediately, any glass or screen I fit this way always lifts up. The adhesives that come with the parts always seem weak. I try B-7000 glue or/and double sided tape, but still it won’t sit tight.
Smeargle - Yanıt
Hi Smeargle, the options you already tried are also the ones I’d recommend. When applying new double-sided adhesive I’d also suggest slightly heating the glued area and applying some pressure for a few hours (stack of heavy books overnight might do).
Tobias Isakeit -
Hey how do you get the huawei sealed back?
For it to be waterproof again.
Léo Zakri - Yanıt
You either buy a rear glass with seal attached or buy a seal and do it yourself, not sure why the author didn't go over this…
jasro -
Although I understand the steps, why did you not include steps to install the fresh rear glass?
jasro - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 32
Son 7 gün: 171
Son 30 gün: 682
Her zaman: 23,924
